want inbox on toolbar to reference icloud messages
Frank D
Outlook 2007
I switched to icloud and am happy with one exception. The inbox on the outlook toolbar does not "point to" icloud messages.
A folder does reference the icloud messages but it would be more convenient if the toolbar could reference it.
Is that possible?
The icloud calendar can't be set as default. Outlook should remember that it is selected and you can move it to the top of the list, but it's always going to use the calendar in your pst as the default calendar. (Same applies to Contacts and Tasks).
I have a macro that can copy new items ot the icloud - Copy New Appointments to Another Calendar using VBA
Frank D
Outlook 2007
On behalf of everyone, thanks for the very quick response.
I'm confused. My question was about the inbox. Your response is about the calendar. Are they treated the same way?
Thanks again.
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
E Outlook 2016 Inbox search bug Using Outlook 1
LolaArrabal My huge inbox folder Using Outlook 2
M Emails being sent to Inbox and IPM_Subtree Using Outlook.com accounts in Outlook 4
S Accepting meeting request from calendar keeps the meeting request in the inbox Using Outlook 2
E Inbox field customization Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
Diane Poremsky Category Color doesn't Display in Inbox New Slipstick.com Articles 0
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
A Can't add a column called "name" to Inbox? Using Outlook 1
V Not displaying newest messages in Inbox Using Outlook 10
Yasemin Nielsen Combined inbox outlook 2016 Using Outlook 2
D How to Run a Report Based on Age of Inbox Items Outlook VBA and Custom Forms 0
R Tasks showing up in inbox? Using Outlook 15
M Cannot Delete Emails from IMAP inbox Using Outlook 4
