Automation error running VB macro code
Big Red
Outlook 2013 64 bit
Exchange Server 2010
I have several macros that run various rules or groups of rules the move emails between folders in my Outlook 2013 mailbox. This works fine on my current Windows 7 PC. I am in the process of migrating over to Windows 10 also running Outlook 2013. While migrating the rules I ran into a problem where I am unable to run the macros. Each macro I run produces an automation error:
Run-time error '-2147221233 (8004010f)': Automation error
Here is the sample code I am trying to run:
Sub RunForeFrontRule()
Dim st As Outlook.Store
Dim myRules As Outlook.Rules
Dim rl As Outlook.Rule
Dim runrule As String
Dim rulename As String
Dim cf As Folder
rulename = "Forefront"
Set st = Application.Session.DefaultStore
Set myRules = st.GetRules
Set cf = Application.ActiveExplorer.CurrentFolder
For Each rl In myRules
If rl.RuleType = olRuleReceive Then
If rl.Name = rulename Then
rl.Execute ShowProgress:=True, Folder:=cf
runrule = rl.Name
Set rl = Nothing
Set st = Nothing
Set myRules = Nothing
When I try to debug the code it goes straight to the first NEXT and stops. I have been searching high and low trying to find a solution with no luck.
Please help. I am desperate at this point.
Big Red
Outlook 2013 64 bit
Hi Michael,
Thank you for your response. Here is the list of entries checked within VB:
Visual Basic for Applications
Microsoft Outlook 15.0 Object Library
OLE Automation
Microsoft Office 15.0 Object Library
Microsoft Outlook View Control
Kind Regards
Martin
Michael Bauer
Ok, I thought the OLE Automation is missing.
I'd walk through the code execution step by step by pressing f8, and see where it doesn't behave as expected. For instance, which line is executed before the error comes up, is any rule exucted at all?
Big Red
Outlook 2013 64 bit
I've stepped through all the lines and did not encounter any problems.
Big Red
Outlook 2013 64 bit
No. If I try to run the code as a whole it still keeps failing with an automation error.
Michael Bauer
Maybe a DoEvents before the Next line will be helpful.
T Outlook Prf/Automation question Using Outlook 2
T Programatic execution of New-MailboxSearch using PSObject (System.Management.Automation) fails with 'Unable to execute the task. Reason: The task Exchange Server Administration 2
J Message automation: message size growth Outlook VBA and Custom Forms 2
D Outlook2007 Email problem with automation Outlook VBA and Custom Forms 4
J Security Restriction Seriously Hampers Outlook Automation Outlook VBA and Custom Forms 1
X Access Outlook Contact Groups with Automation? Outlook VBA and Custom Forms 3
J Adding a background image to a mail item using automation Outlook VBA and Custom Forms 2
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
Diane Poremsky The Attachment Size Exceeds the Allowable Limit Error New Slipstick.com Articles 0
Diane Poremsky RMS Error: System clock has been tampered with New Slipstick.com Articles 0
Diane Poremsky Error Opening Outlook and Control Panel's Mail Applet New Slipstick.com Articles 0
K Error: Paper Size Invalid Using Outlook 0
