BCM 2010 randmoly going offline
The Weekly Geek
Modem died, replaced. DNS is external DNS as was on previous modem.
Ever since then BCM 2010 drops connections on all computers (8) several times a day.
Connections do not drop at the exact same moment. Usually 2 or 3 will drop within 5 minutes of each other.
Other computers may not drop for a couple of hours.
Most of the time can manually reconnect. Sometimes have to reboot PC to reconnect.
BCM is on Windows Small Business Server 2011 Essentials.
PC's are all Office 2010. Some of Win 7 x32, some are Win 7x64 and two are Win 8 x64.
Forum Admin BCM Update for Outlook 2010/2013 - Nov 2014 BCM (Business Contact Manager) 14
JimR BCM 2010 or 2013 BCM (Business Contact Manager) 6
J Migration from BCM 2010 to 2013 is messing up the label fields BCM (Business Contact Manager) 4
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
R BCM 2010 Problem with remote office (VPN) users cannot connect BCM (Business Contact Manager) 12
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
R BCM is almost at capacity Outlook 2010 BCM (Business Contact Manager) 2
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
V Permissions in BCM 2010 BCM (Business Contact Manager) 3
M Is there a list of FieldNames that BCM 2010 uses? BCM (Business Contact Manager) 0
A BCM 2010 converts html e-mails to plain text BCM (Business Contact Manager) 1
A BCM 2010 account names import in reverse order BCM (Business Contact Manager) 4
B BCM 2010: Exporting Notes to .CSV with Business Contacts? BCM (Business Contact Manager) 3
J BCM 2010 - New user cannot connect to remote DB BCM (Business Contact Manager) 5
E Can we make custom form as default form in BCM 2010? BCM (Business Contact Manager) 5
N BCM 2010 for CRM tool? BCM (Business Contact Manager) 3
S BCM 2007 to 2010 migration failure issue BCM (Business Contact Manager) 1
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
M BCM 2010 Cannot Connect to Remote Database BCM (Business Contact Manager) 1
M BCM 2010 Link to Record (very) slow BCM (Business Contact Manager) 2
D [SOLVED] Optimizing Outlook 2010 BCM BCM (Business Contact Manager) 2
C Outlook 2010 with BCM - Database Connection problems using Windows 7 Clients Using Outlook 1
T Custom forms BCM 2010; use of form controls Using Outlook 1
S Recovering .sbb file that should be a .bcm file for Business Contact Manager 2010 Using Outlook 3
M Where are contacts stored for BCM 2010? Using Outlook 1
I Outlook 2010 BCM Mass E-mail feature insists on converting outbound HTML emails to plain text Using Outlook 2
I Office 2010 BCM Using Outlook 1
N Receive "Requested Operation Failed" Dialog when trying to add BCM Database in Outlook 2010 Using Outlook 2
B Outlook with BCM 2010 and Windows Mobile will not sync contacts separately Using Outlook 1
P Communication History disappeared in BCM 2010 Using Outlook 22
D BCM for Office 2010 Pro Plus Using Outlook 1
R BCM 2007 to 2010 Conversion fails - Database size > 4GB Help! Using Outlook 1
G Importing BCM file into Business Contact Manager 2010 Using Outlook 3
Forum Admin Download BCM 2010 BCM (Business Contact Manager) 0
T Import Outlook 2003 .bcm file into Office 2010 Bus. Cont. Mgr. Error: "Input string was not in a cor Using Outlook 6
C BCM 2007 to 2010 Migration BCM (Business Contact Manager) 1
A Using BCM 2010 mass email - how do you control which outlook email account does the sending? Using Outlook 6
S Where can I download BCM 2010 stand alone? Using Outlook 29
R Missing contacts and Opportunities in BCM 2010 Shared database BCM (Business Contact Manager) 1
M BCM for Outlook 2010 now on Technet BCM (Business Contact Manager) 2
J BCM 2010 BCM (Business Contact Manager) 1
