.ost file problem
Hi friends I hope all you fine and well
I have a problem that I tried to solve but I could not I hope some one to help
I set up an new account instead old one that had a missed password that I deleted the new one has an extension data fil .ost whenever I tray to make a password for the new account that created a dialogue box appears asks me to compress the data file I do but nothing changed I need to know what should I do to solve such problem
with regards
ost means the account is configured as an imap or exchange account - you can't password protect these data files. Only pst files can be password protected and only pop3 accounts use a pst (plus you can use a stand-alone pst).
By default, outlook's autodiscover will create an imap account if it is supported by your server.
ok thanks mrs. Diane for your responce but now i need to make a password on that account because the pearson that has this a ccount asked me to secure its account can i find a way to convert .ost file to .pst than put a password on the a ccount
or delete .ost and replace it with .pst with re creating again the same account
thanks
If you need to password it, you need to delete the account and manually add it back as a POP3 account. Personally, rather than using a password on a pst, i would use one on the computer and lock it when i walked away. If others need to use the computer, they should have their own windows logon.
so. but mrs. Diane the account htat i established is an exchange account what i mean that it is on a private server not on yahoo , gmail or others like them if my thinking is wrong would you please give thr procedures step by step of deletion and conversion i mean that you write them into elements to follow them
thanks with regards
DoctorJellybean Preserve OST file location in new installation? Using Outlook 4
S Moving .OST file location unsuccessful! Using Outlook 6
BretAB Connected vs Connected Headers vs OST file. Exchange Server Administration 2
BretAB Connected vs Connected Headers vs OST file. Using Outlook 2
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
I Outlook 2013 Any way to move .OST file to new system? Using Outlook.com accounts in Outlook 5
R ost file import Using Outlook 2
O Moving .ost file Using Outlook 12
C Converting OST to PST File Using Outlook 3
B How to recover deleted MS Outlook OST file? Using Outlook 4
T OST vs PST file size Using Outlook 2
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
Diane Poremsky Convert an Offline File (.ost) to a Personal File (.pst) New Slipstick.com Articles 0
S How to do I convert OST file to PST? Exchange Server Administration 3
S Is it possible to recover a permanently deleted email from my .OST file? Using Outlook 0
R can I transfer outlook data from old pc by using .ost file instead of the .pst Using Outlook 5
Diane Poremsky Moving an Outlook offline data file (*.ost) New Slipstick.com Articles 3
V Import from Outlook 2013 ost file? Using Outlook 2
H Can't change the location of the Data File (.ost) in Outlook 2013 Using Outlook 2
Tony H. I want my OST file permanently deleted Using Outlook.com accounts in Outlook 5
D Outlook 2013 .ost File Size Exchange Server Administration 2
M How do I Repair OST File from corruption and Recover OST data? Using Outlook 3
O Previous OST file items are inaccessible Using Outlook 1
B Outlook 2010 won't configure exchange account, 0kb .ost file Exchange Server Administration 5
R How to recover old hotmail messages from an .ost file Using Outlook.com accounts in Outlook 3
D Unable to open hotmail, error hotmail.ost is not an offline folder file Using Outlook 3
K Extracting Calendar information from a OST file? Exchange Server Administration 5
J Outlook 2019 i dont want to buy the snake oil ost to pst programs Using Outlook 1
L Restoring Outlook from backup of OST Using Outlook 5
V Carbonite not backing up .ost files Using Outlook 7
E How to transform .OST in .PST ? Using Outlook 1
C OST email backup Exchange Server Administration 1
myPalabok not all emails are in OST Using Outlook 2
C convert an .ost to .pst Using Outlook 3
