Folder Pane problems
Oldmaven
1) The shortcuts listing at the top of the folder pane has disappeared--how do I get it back?
2) The folder listing is double-spaced, so it show half as many folders as I'd like. Is this fixable?
I'm running Outlook 2016 under Windows 10 Pro x64
Oldmaven
No matter what the source, advice I get on Office 2016 frequently tells me to click an option that I cannot find.
Clicking Folder Pane gives me a Navigation Options window listing maximum number of visible items (currently 4), Shortcuts, Mail, Calenda, People, Folders, Tasks, and Notes. Nothing on Favorites.
Is this another feature that's defeated for IMAP?
Dan Liberman
Outlook 2016 64 bit
1. View tab, Folder pane button > Favorites should be checked.
2. Sounds like you have touch mode turned on. click the finger icon in the QAT or see Tip 1107: Outlook's Touch Mode - Outlook Tips
Diane, I love your knowledge but this is a problem since Outlook 2013. The folder pane spacing is almost double spaced even with touch mode turned off. I, and many others, just want to be able to glance at the folder pane see our favorites and our accounts without having to scroll all the time. Before '2013 this was not an issue.
I am an a small businessman using office365 but for the first time am seriously considering moving away form the Microsoft community. I get a newsletter several times/week about all the great new stuff in office365 but these simple fixes are ignored . Fix what needs to be fixed and don't fix what doesn't need to be fixed.
What zoom level are you using? You could try restarting outlook with the /resetnavpane switch but I'm not sure it will fix it (and you'll need to customize it.)
This is a comparison of regular and touch mode side by side - is the gap you see larger?
B Outlook 365 - Folder pane list clears Using Outlook 26
R Folder pane width change Using Outlook 59
N Wide Line Spacing in Folder pane 2016 Using Outlook 18
GregS What controls content of Folder Pane? Using Outlook 1
Diane Poremsky Outlook's Folder Navigation Pane Disappears New Slipstick.com Articles 2
L Should public contacts folder appear in "People" nav pane? Using Outlook 1
V Open Outlook Calendar and Tasks views with Folder pane off Using Outlook 2
Y (Shared Folder) Using the preview pane to open and close a fax, without opening the email itself Using Outlook 1
S Outlook 2013: Permanently Unhide Scroll Bar in Folder Pane? Using Outlook 7
J How To Change Font Size For Folder Names on Navigation Pane in Outlook 2013 Using Outlook 1
M Folder View in Unread Mail Pane - Outlook 2003 Using Outlook 6
N Favorite Folders list in outlook navigation pane, can you add a message to the favorite folder list Using Outlook 2
Y View Reading Pane for Drafts folder Using Outlook 2
M Move to Folder Using Outlook 1
K Export Folder to PST Outlook VBA and Custom Forms 2
B Spam folder not showing in Outlook Using Outlook 5
J Moving Imported folder Using Outlook 2
B VBA to Collapse Task Folder Groups Outlook VBA and Custom Forms 1
D Outlook 2016 Deleting emails without affecting folder structure - Outlook Office 365 Using Outlook 3
T Missing Folder in Outlook.com Using Outlook 3
N Outlook 2016 Folder Icons Look Using Outlook 0
R Deleting emails from storage folder Outlook VBA and Custom Forms 1
B Outlook - Mail from safe senders list being sent to Spam Folder Using Outlook 0
R Search/Jump to a folder by typing its name Outlook VBA and Custom Forms 1
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
