Help with code to move mail on receipt to another folder based on time received
Doug Horton
Outlook 2013 32 bit
I have a motion sensing security camera in my server room. It sends a mail message with a snapshot any time motion is detected. I'm trying to create a rules script that moves those messages received between the hours of 6am and 6pm to another folder (so I don't have to see them in my inbox during the day).
The following VBA code was created for this purpose:
Sub ProcessServerCamMail(Item As Outlook.MailItem)
Dim strFolder As String
Dim rectime As Date
rectime = TimeValue(Item.ReceivedTime)
strFolder = "ServerCams"
If rectime > TimeValue("6:00 am") And rectime < TimeValue("6:00 pm") Then
Item.Move Session.GetDefaultFolder(olFolderInbox).Folders(strFolder)
End If​
End Sub​
The problem I am having is that this only works if the destination folder is a subfolder under "Inbox". However, my subfolder is at the same level as Inbox. In other words, it's a subfolder of the mailbox, not Inbox.
How can I modify this to work with "ServerCams" folder at the same level as my Inbox?
We are using Exchange 2007 and Outlook 2013.
Doug.
M help correct code Using Outlook 0
M Updates to exchange server broke code - please help Using Outlook 2
S 0x800CCC33 error code. 'access to the account denied' 'server responded forbidden. Please help. Using Outlook 1
R Chat wants product code, no code matching the format of the example is on the box. Outlook does not delete downloaded email from the server, help is U Using Outlook 1
D Help Need Fix-Cant connect to server , then error's out - Synchornizing Sub Folders Error Code ox800cccoe Using Outlook 1
J Unable to send outgoing email. error code 0x800cccoe socket error 10013 port 25.please help Using Outlook 1
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
S HELP: How do I code a button I created? Outlook VBA and Custom Forms 1
C Beginner Needs VBA Help in Modifying Code Outlook VBA and Custom Forms 2
B HELP! Using Outlook 4
M Winmail. dat - HELP Using Outlook 2
Diane Poremsky Help! My Contacts are being updated! New Slipstick.com Articles 0
B VBA Help Email that will save as draft and send as attachment Outlook VBA and Custom Forms 3
J Can Anyone Help?? Outlook VBA and Custom Forms 1
G Looking for help with our Organization Forms Library Outlook VBA and Custom Forms 1
