SMTP messages stuck in Outbox
Tony Russo
We use MDeamon V16.02 with Outlook Connecter for server / users have Office 2010 32-bit
This is weird it is only happening in one remote office for three users. When I send just a plain text email to them it is received in real time. When I reply or send a new message from their accounts as plain text text it goes to Outbox and stays 20-60 seconds before it sends from their system. Once it leaves the Outbox it is received by recipient in a normal expected time. I tested this to both to an internal and external address, with same result. When you attach a file around 2mb for this testing it can take up to 20-40 seconds before it goes to the outbox and can stay there 30 – 90 seconds before leaving. I am sure these times would multiply by the bigger file size as well as other traffic creating longer delay.
I have added host file direct paths, tweaked outlook and created straight pipe to mail server on the firewall. Those changes were put into effect over the weekend. My testing did not prove any change in results. I have not uninstall Office/Outlook.
C SMTP Relay: messages stuck in Queue folder Using Outlook 3
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
Diane Poremsky Exchange Server and SMTP Servers New Slipstick.com Articles 0
Diane Poremsky Common Outlook Outgoing Server (SMTP) Errors New Slipstick.com Articles 0
S Outlook 2013 sends plain text with attachment mail as uuencoded with SMTP conn Using Outlook 2
T Outlook 2013, McAfee Security Suite and SMTP/POP3 Using Outlook 3
E msg attachments lose their recipients "smtp" address Using Outlook 2
H Mailing List account needed with remote smtp auth facility Exchange Server Administration 3
K External Mtg Invitees have =SMTP: added to email address after mtg saved Using Outlook 5
C How to get SMTP out of email address when exporting contacts? Using Outlook 2
N Beginner - Setting SMTP settings/travelling Using Outlook 4
C Custom Form that allows a single SMTP header to be parsed to Field Chooser? Using Outlook 4
N cannot send emails-SMTP Ports not working for Hotmail Pop3 Using Outlook 3
D how can bounce email be captured in smtp server Exchange Server Administration 3
williamlambton Changing 'To' field in message lists to show SMTP address only. Using Outlook 2
S change smtp in exchange account Using Outlook 1
I Outlook on laptops with different ISP SMTP Using Outlook 3
O An unknown error has occurred.____Server: 'smtp.west.cox.net'__Windows Live Mail Error ID: 0x8007005 Using Outlook 3
S Internet Mail SMTP Connector Problem on Exchange 2010 after Migration Exchange Server Administration 2
A Task 'Hotmail - Sending' reported error (0x800CCC7D) : 'Your outgoing (SMTP) server does not support Using Outlook 8
T smtp outgoing email server could not be connected Using Outlook 2
R Sending e-mail Outlook 2003(SMTP) using SSL and port 587 Using Outlook 4
S smtp error when password changed but works again with old password Using Outlook 1
K Email sends with no error, but no action on the SMTP server done, only authentization - for some of the outgoing addresses. Using Outlook 1
A Outlook 2010 Exchange / SMTP: unable to send Using Outlook 2
S There was a SMTP communication problem with the recipient's email server. Please contact your syste Using Outlook 2
T How do I get multiple pop3/smtp email accounts to point to the Default Personal Folder in Outlook 20 Using Outlook 5
D How to setup an SMTP Drop and Queue Folder in same Domain for relay??? Exchange Server Administration 4
S Incoming and Outgoing SMTP server settings Using Outlook 7
N Get SMTP address of sender in outlook 2003 Outlook VBA and Custom Forms 5
V Recipient's SMTP address Outlook VBA and Custom Forms 1
Y Sending message with multiple SMTP BCCs Outlook VBA and Custom Forms 2
M Getting the SMTP address from an EX address Outlook VBA and Custom Forms 7
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 1
S Conditional Formatting for messages in a Conversation thread Using Outlook 1
GregS Outlook 2016 Sent Items vs Sent Messages Using Outlook 2
snissen Printing foreign language messages Using Outlook 1
S Receiving duplicate messages from RSS feeds Using Outlook 3
R Can't send messages to groups in Outlook Using Outlook 2
icacream outlook keeps neither SENT or FORWARDED messages... they vanish ! Using Outlook 4
