Error using AddressEntry.GetContact - need help
SmileyFtW
I am trying to do some automation on distribution lists, but am running into a snag. In a distribution list the GetMember method returns a Recipient object which has a limited amount of information and I want to get the Contact object represented by the Recipient. I test to make sure the recipient is resolved, but when I attempt to use the AddressEntry.GetContact method I get a run time error. What am I doing wrong or what else do I need to do?
Set myNameSpace = Application.GetNamespace("MAPI")
Set myFolder = myNameSpace.GetDefaultFolder(olFolderContacts)
Set myFolderItems = myFolder.Items
iCount = myFolderItems.Count
For x = 1 To iCount
If TypeName(myFolderItems.Item(x)) = "DistListItem" Then
Set myDistList = myFolderItems.Item(x)
For y = 1 To myDistList.MemberCount
Set myRecipient = myDistList.GetMember(y)
RecipientIsResolved = myRecipient.Resolved
If RecipientIsResolved = True Then
Set myAddressEntry = myRecipient.AddressEntry
Set myContactItem = myAddressEntry.GetContact '<Errors here with "The item could not be found"
With myContactItem
'Here I would be able to access all of the contact's information
Debug.Print myDistList.GetMember(y).Name
' If myDistList.GetMember(y).Name = myNameSpace.CurrentUser.Name Then
' MsgBox "Your are a member of " & myDistList.DLName
' End If
Next y
Next x
David
Michael Bauer
I could never figure when that function works and when it doesn´t. I´d use the Items.Find function of the contacts folder and search the email address myself.
SmileyFtW
I actually came at the problem from a different angle and got what I needed. I used the Restrict method on the contacts folder and then looped the restricted contact items. The Outlook object model is so convoluted compared to the Excel OM.
S Autosave attachments error using Len Outlook VBA and Custom Forms 2
B 0x800CCC0F Error using POP3 in Outlook 2010 and 2013 Using Outlook 1
H Send/Receive Error Sending E-Mails Using POP3 GMail Account Using Outlook 2
A Synchronization Error of contacts and calender using Outlook connector Using Outlook.com accounts in Outlook 12
A Error: 3033 when trying to OpenDatabase using DAO Outlook VBA and Custom Forms 3
S Outlook 2007 error message using the TASK feature Using Outlook 6
Cathy Rhone Mail merge error message Using Outlook 2
O Comma Separated Values.ADR and A file error has occurred in the translator Using Outlook 6
D Outlook 2016 Outlook Error Msg "The operation cannot be performed ..." How to Stop it Using Outlook 4
A Error: The name cannot be matched to a name in the address list Using Outlook.com accounts in Outlook 0
