How to Copy Multi Select Listbox Data to Appointment
George Z
Outlook 2013 64 bit
With the help of various tutorials in this form I am trying to combine input data from several different input types into an outlook appointment item. With your assistance I have been able to include data from both message boxes and list boxes. How do you also include multiple selections from a multi select list box? I have been able to capture the selections in an array and display them in a message box. Though have not been able to copy the array data into the appointment subject. I have attached both the custom form code, and the macro code. I am at the point where I am unable to identify where to go from here. As always, any assistance is greatly appreciated. I am not sure if I am way off on this or close to a solution.
  • Form Code.txt
  • MacroCode.txt
George Z
Outlook 2013 64 bit
Not sure how to apply this as you are stating. I am joining the array and displaying as message. I need the join to be included in the subject with data from other sources. Below is code for the Form. I bolded the lst reference also bolded line from macro code adding data to subject. How do I reference the array in the macro code? I separated my form and macro code in original post. . With the code below array I get type mismatch error. Thanks again for your continued support. Appreciate all the feedback.
Private Sub ComboBox2_Change()
Private Sub UserForm_Initialize()
With ComboBox1
.AddItem "INSP"
.AddItem "PM"
.AddItem "LOAD TEST"
.AddItem "OR"
With ComboBox2
.AddItem "ANNUAL"
.AddItem "SEMI-ANNUAL"
.AddItem "QUARTERLY"
.AddItem "MONTHLY"
.AddItem "ADHOC INSP/PM"
.AddItem "OR"
With ComboBox3
.AddItem "BEATON 19FT"
.AddItem "BEATON 28FT"
.AddItem "BEATON 32FT"
.AddItem "RENTAL"
.AddItem "CUSTOMER PROVIDED"
.AddItem "NOT REQUIRED"
With ListBox1
.AddItem "BRIDGE CRANE"
.AddItem "GANTRY CRANE"
.AddItem "JIB CRANE"
.AddItem "MONORAIL CRANE"
.AddItem "POWERED HOIST"
.AddItem "CHAINFALL HOIST"
.AddItem "BELOW HOOK DEVICE"
.AddItem "WINCH"
With ListBox2
.AddItem "OVERHEAD DOOR"
.AddItem "SPEED DOOR"
.AddItem "COILING STEEL DOOR"
.AddItem "IMPACT DOOR"
With ListBox3
.AddItem "VEHICLE LIFT"
.AddItem "ENGINE LIFT"
.AddItem "MATERIAL LIFT"
.AddItem "PALLET JACK"
.AddItem "JACK STAND"
.AddItem "MATERIAL LIFT TABLE"
.AddItem "WALKIE STACKER"
.AddItem "STRAPPING/BANDING MACHINE"
With ListBox4
.AddItem "BOOM ATTACHMENT"
With ListBox5
.AddItem "AUTO SCRUBBER"
With ListBox6
.AddItem "DOCK LEVELER"
With ListBox7
.AddItem "BAILER/COMPACTOR"
With ListBox8
.AddItem "VRC"
.AddItem "SELF RETRACTING LIFE LINE"
.AddItem "TRIPOD"
.AddItem "HORIZONTAL LIFE LINE"
With ListBox9
.AddItem "TRUCK RESTRAINTS"
With ListBox10
.AddItem "METAL MESH SLINGS"
.AddItem "SYNTHETIC ROUND SLING"
.AddItem "SYNTHETIC WEBBING SLING"
.AddItem "WIRE ROPE SLING"
.AddItem "ALLOY STEEL CHAIN SLING"
Private Sub CommandButton1_Click()
Dim I As Long
Dim J As Long
Dim msg As String
Dim arrItems() As String
ReDim arrItems(0 To ListBox1.ColumnCount - 1)
For J = 0 To ListBox1.ListCount - 1
If ListBox1.Selected(J) Then
For I = 0 To ListBox1.ColumnCount - 1
arrItems(I) = ListBox1.Column(I, J)
Next I
msg = msg & Join(arrItems, ",") & vbCrLf & vbCrLf
Next J
MsgBox msg
lstNo = ComboBox1.ListIndex
lstNo2 = ComboBox2.ListIndex
lstNo3 = ComboBox3.ListIndex
'lstNo4 = ListBox1.Selected(I)
lstNo4 = Join(arrItems, ",")
' lstNo5 = ListBox2.ListIndex
' lstNo6 = ListBox3.ListIndex
' lstNo7 = ListBox4.ListIndex
' lstNo8 = ListBox5.ListIndex
' lstNo9 = ListBox6.ListIndex
' lstNo10 = ListBox7.ListIndex
' lstNo11 = ListBox8.ListIndex
' lstNo12 = ListBox9.ListIndex
' lstNo13 = ListBox10.ListIndex
Unload Me
Here is my line from macro
If objContact.CompanyName <> "" Then
objAppt.Subject = objContact.CompanyName & ", - INSP/PM - ," & inputdata & " , " & strBody1 & strBody2 & strBody3 & inputdata1 & "," & strBody
Michael Bauer
You do have the values of the array in the lstNo4 variable, don´t you? Just add it to the subject as you already do with the other variables.
Diane Poremsky Copy New Appointments to Another Calendar using VBA New Slipstick.com Articles 0
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
I How to make a copy of a task Using Outlook 8
F copy data in Custom Field to other folder Outlook VBA and Custom Forms 2
A Outlook: copy & paste Outlook VBA and Custom Forms 9
L Copy email body fields to excel Using Outlook 0
C How to copy same text header to multiple emails with custom text column Using Outlook 10
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
A Macro to Copy Data from Outlook to Excel Spreadsheet Using Outlook 2
D How to copy yahoo email folders to hard drive Using Outlook 2
