Fonts in Outlook 2007
Bluenose
Hello
When I go to Tools | Options | Stationery and Fonts in Outlook 2007 the button to change fonts is greyed out.
Is there a way around this, please, so that my fonts are consistent throughout?
so you can click the stationery & fonts button, just not change fonts? Is this a corporate computer? It sounds like a policy could be in effect that sets the fonts.
Policies are in the registry at HKEY_CURRENT_USER\Software\Policies\Microsoft\office
Bluenose
Thank you for your reply.
No, it's a stand alone PC at home.
Exactly: Tools | Options | Mail Format.
I can choose the not under 'Replying and Forwarding Messages' and 'Composing and Reading Plain Text Messages', but not 'New Mail Messages'.
Thanks again
Do you have a default theme set for new mail?
if you use a theme and choose either use themes font or use my font when replying, one or both buttons for HTML/RTF messages will be grayed out.
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
B Fonts cut off when composing new email on outlook 2007 Using Outlook 1
M All fonts in Outlook emails display with exaggerated character spacing Using Outlook 3
L Ever notice that the fonts in Outlook seem to be depend on the build? Using Outlook 1
e_a_g_l_e_p_i How to set fonts for emails in all folders in Outlook Using Outlook 1
N Outlook 2010 prints in small fonts Using Outlook 1
P Outlook Fonts not Sticking Using Outlook 10
D Point Size for Fonts in Custom Font Style (Outlook 2013) Using Outlook 0
N Column view fonts Using Outlook 4
O Non-standard fonts - are they embedded? Using Outlook 2
T Incoming Mail Changes Fonts Using Outlook 0
L How to use different fonts for outgoing messages for different email accounts Using Outlook 0
e_a_g_l_e_p_i Just had to reinstall window 10 then Office and forgot how to control fonts sizes Using Outlook 3
Commodore What's the deal with fonts Using Outlook 6
E fonts suddenly bigger by 2x Using Outlook 3
F How to change all incoming fonts to black? Using Outlook 3
K Default Fonts Using Outlook 9
T Text fonts changing when exchange syncs Using Outlook 0
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 13
@ Outlook Using Outlook 2
