rule to flag messages not working
Anand
Hi, I recently started using Outlook 2016. (I had been using 2003 up till now). I want every message that comes in to be flagged for follow up. I created rules that flags messages from each of my accounts to be flagged. Now the weirdest thing is that it works sometimes, and not at other times. Some messages get a flag, and others don't, even when they come in through the same account. I have tried so many things, deleting rules, creating them again, nothing seems to work.
I use Win10.
In Outlook 2003 this worked just fine... :-(
Anand
Hello, thanks for responding. Everything is pop3. Mail comes in a few at a time only.
if you use run rules now, does it flag the messages? that can rule out a problem with the rule.
Anand
Good question, yes, I tried, if I run them manually they do okay.
Anand
I did a pst repair. This seems to have solved the problem.
L Making rule to move email to folder from one O365 domain Using Outlook 1
Ascar_CT Rule behavior analysis - any tools available? Using Outlook 0
Liza Creating a rule in outlook to filter messages Using Outlook 0
M VBA Rule for removing all body but hyperlink then forwarding Outlook VBA and Custom Forms 9
B custome rule Outlook VBA and Custom Forms 2
Diane Poremsky Mark Sent Items as Read After Copying with a Rule New Slipstick.com Articles 0
Diane Poremsky Run a Script Rule: Send a New Message when a Message Arrives New Slipstick.com Articles 2
T Create Rule For Secondary E-Mail Address In Outlook 2016 Using Outlook 4
C Rule To Save attachments on receipt of email Outlook VBA and Custom Forms 2
Diane Poremsky Create a Task from an Email using a Rule New Slipstick.com Articles 0
M Rule option Using Outlook 2
O VBA rule on multiple computers using shared mailbox Outlook VBA and Custom Forms 1
J Transactional emails - mail rule Using Outlook 3
M Question: Is there a rule that will save email in Windows Explorer Outlook VBA and Custom Forms 3
