VBA Macro to highlight some Keyword in mail body?
yjsfox
Hi, I have been looking for a method to do keyword (including whole line) highlight (coloring is better) if the incoming mail body matched some rules/expr.
Say, I want to highlight the line "05/12/2017: 2 Hours On Fri; Category: Vacation - SJ" by matching rule: lines with date in start and has "Category:"
Is that doable in outlook VBA macro?
Thanks!!!
(I am using outlook 2016 and outlook 2013)
-- mail body--
Time Off Request Details:
Time Off Plan Balances as of 05/12/2017:
----mail body--
you can use regex to match, but you would need to rewrite the html to highlight it. Adding the category is no problem. If the line has special formatting already, it would probably be easier to do (since the html formatting already exists, just need to add to the style.)
Actually... the simple script in this url works - as long as that line has unique formatting you can look for and replace.
How to Change the Font used for Outlook's RSS Feeds
(ETA: i just tested it - works fine - just make sure you use the right value for oldfont. I should change the order of the strings so oldfont is entered first, then new. :))
yjsfox
Hi, Thanks for the hint. Sorry that I didn't try it until these days.
I am not very familiar with the regex. That's what need help for.
My purpose is to highlight the name and date/time in the Mailbody so it will look like this:
(Note the name and date/time has been bold faced to make it easier to read)
You have a new Workday business process pending approval for John Smith. You can now process this request via email reply or by logging into Workday to approve or reject this request.
08/25/2017: 8 Hours On Fri; Category: Floating Holiday - SJ
The bold face is not fixed so I definitely need regex to match the strings Ineed (name and date/time).
I have managed to do it using the following code. "nearly right" but need to refine the target string (wordToSearch) to be a regex extracted string.
The folloiwng code only get the "business process pending approval for" highlighted
Sub HighlightString (MyMail As Outlook.MailItem)
Dim strID As String
strID = MyMail.EntryID
Set objMail = Application.Session.GetItemFromID(strID)
wordToSearch = "business process pending approval for "
' Ineed to find a way to match keyword from this line, assigned to wordToSearch
If InStr(1, objMail.HTMLBody, wordToSearch, vbTextCompare) > 0 Then
strData = objMail.HTMLBody
strData = Replace(strData, wordToSearch, "<FONT style=" & Chr(34) & "BACKGROUND-COLOR: yellow" & Chr(34) & ">" & wordToSearch & "</FONT>")
objMail.HTMLBody = strData
objMail.Save
Set objMail = Nothing
Thanks much for the help in advance!
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 8
