Icloud Contacts With Outlook Issue
Galaxymednet
Hello.
A good customer of mine has issues whereby all contacts stored in iCloud do not show up in Outlook 2007 and both programs are synced.
For example she has 580 contacts in iCloud but in Outlook it will show like 515 or so. Why won't all show up? I know this website is a great authority on all things Outlook and that is why I became a member.
I have read the articles regarding issues like this but something is missing and I hope someone can help out.
Just FYI. She is on Windows 7 Ultimate SP-1 plus all updates as of May of this year. Outlook is 2007 version SP3 plus all updates after. I believe she has the latest iTunes (Does that matter?) and iCloud is latest version.
She does have an iPhone 5s with IOS 9 or 10 I believe. Let me know if you need any other info?
Thank You
No ideas... but if you could inspect the ones that don't sync, you might notice something (or not).
Have you tried signing outlook of icloud on the computer and signing back in to see if more sync?
Brendan Keeping Outlook contacts on PC after signing out of icloud Using Outlook 1
S Using iCLoud Contacts for Outlook Email Using Outlook 1
I iCloud Calendar and Contacts in Outlook 365 Using Outlook.com accounts in Outlook 2
R Moving contacts from ICloud back to Outlook 2010 Using Outlook 4
yooper46 Removal of iCloud contacts in Outlook contact list Using Outlook 8
V Sync Outlook contacts/calendar on two computers using iCloud Using Outlook 2
D Can't Use Contacts with Mail & iCloud in Outlook 2007 Using Outlook 7
N iCloud deleted my Outlook 2010 contacts Using Outlook 1
D Search iCloud contacts from Outlook 2010 CTRL-E Using Outlook 4
C Remove iCloud so I can have original outlook calendar and contacts Using Outlook 43
M icloud removed my contacts Using Outlook 7
makinmyway Appointments Created in iCloud Calendars Cover Contacts Field...Why? Using Outlook 3
T Deleting iCloud Synced Contacts Exchange Server Administration 2
V iCloud combined all Contacts? Using Outlook 1
pedropimenta@netcabo.pt Sync Business contacts with Icloud contacts BCM (Business Contact Manager) 1
J Lost contacts.pst afer sync with iCloud: where has contact.pst disapperaed to? Using Outlook 3
E How to create contacts group list with IMAP/iCloud? Using Outlook 2
C Lost calendar and contacts to icloud: Help! Using Outlook 1
M Unable to search Note section in Contacts in icloud Using Outlook 7
J iCloud Calendar/Contacts Syncing Hangs At End - aplzod Data Store Not Created Using Outlook 8
KeithJB iCloud calendar sync only works one way! Using Outlook 3
B iCloud for Windows 11.2 disconnects by itself after 30-45 minutes Using Outlook 9
W Looks like the folder below has been deleted: "iCloud\Calendar" Using Outlook 1
Commodore iCloud mail with two-factor authentication Using Outlook 7
