Transfer Outlook TextBox Text Into Email Body
cdc99999
Outlook 2013 32 bit
I would like to use a form to populate email body text.
Is there any way I can create a form in Outlook and have the various TextBoxes transfer to the email body in predetermined places to avoid people having to copy and paste data into an email template and then have to adjust the font, formatting, etc...?
Basically: Label1--->TextBox1 in form and TextBox1 info goes into a specific place in the email body text (or subject line).
Cheers
you can but it might take a lot of code - and getting it into the right place in the body might be tricky (subject is fairly simple). It would need to be published to the org library to work because you need to have code behind the form.
I don't think i have any forms this complicated to give you as a sample but will look in my stash.
cdc99999
Outlook 2013 32 bit
Many thanks Diane, hopefully you will find something I can work from :)
M Transfer To New Computer - Lost Some Outlook Functionality Using Outlook 0
R can I transfer outlook data from old pc by using .ost file instead of the .pst Using Outlook 5
V Outlook 2013 - transfer autocomplete data Using Outlook 4
Diane Poremsky Transfer POP3 Mail on an iPhone to Outlook New Slipstick.com Articles 7
S Anyone know how to transfer Outlook Express "Identities" to Outlook 2010 ... Using Outlook 1
D Unable to transfer rules from one Outlook computer to another Using Outlook 5
I Is there a way to transfer Windows Address Book files to Outlook? (Contact information FROM Windows Address Book TO Outlook?) Using Outlook 1
C Installing Outlook 2003 on a new Windows 7 Desktop and transferring data via Easy Transfer Using Outlook 3
A Would like to transfer my outlook 2003 contacta and address book to windows live and retain them in outlook as well Using Outlook 2
M Transfer Outlook 2007 PST file to new computer running Outlook 2010 Using Outlook 2
N How do I transfer my address book and folders I currently have in Outlook from my old computer to my new computer? Using Outlook 1
L transfer data from Outlook 2007 to Outlook 2010 Using Outlook 1
O How do I transfer my contacts, calender and tasks from my default outlook .pst file to a windows liv Using Outlook 9
P Outlook Connector Contact Pictures do not transfer Using Outlook 2
A how to transfer outlook 2010 files from 64-bit to 32-bit - easy transfer doesn't work Using Outlook 1
N Transfer Outlook 2007 data file to Outlook 2010. Using Outlook 1
J Problems during Outlook 2010 Transfer to new PC Using Outlook 5
P Transfer several pst files from Outlook 2002 to Outlook 2007 Using Outlook 2
U How to transfer a .pst file FROM an emailed file to my Outlook Using Outlook 1
L I transfer outlook.pst file to my new vista pc, from vista laptop, but Email rules do not work, what's the solution? Using Outlook 2
C How do I transfer Outlook Express files (contacts, inbox, etc) to Outlook (Office 2010)? Using Outlook 2
M Transfer Outlook Express 6.0 Email into Microsoft Outlook Using Outlook 1
B No address book after transferring to Office Outlook 2007 w/Win7 using Easy Transfer from 2003__ Using Outlook 2
M Transfer e-mail from hotmail to outlook express Using Outlook 1
E Data transfer from Outlook 2007 to new email account in Outlook 2007 Using Outlook 1
H How to transfer outlook express 2007 address book and rules between computers (not networked) Using Outlook 2
O would like to transfer all contacts/emails from Outlook Express from old computer to Outlook on new computer. Using Outlook 1
M After EASY TRANSFER - Outlook 2007 PST Files not available?__ Using Outlook 4
S transfer email account settings from Outlook 2007 to 2010 Using Outlook 5
K transfer iphone contacts to microsoft outlook on computer Using Outlook 4
K Outlook 2003 to 2007 data transfer Using Outlook 3
B transfer PST and OST when upgrading from Outlook 2003 to Outlook 2007 Using Outlook 3
P Macros in Word 2003 - how to transfer to another Word 2003? Using Outlook 1
E Some Calendars Not Visible After Transfer Using Outlook 2
A Creating rule to create week folder and transfer mail using alert Using Outlook 3
L Transfer Contacts from old computer to address book in new computer Using Outlook 1
L Transfer Contact Info? Using Outlook 2
F Contacts List Transfer Using Outlook 1
Z Transfer my custom mail folders to new computer Using Outlook 1
B Can I transfer (copy) my emails onto a CD or DVD? Using Outlook 4
F address book and mails did not transfer when migrated from one computer to another Using Outlook 4
J I used a Belkin Easy Transfer kit to transfer files from an old XP based laptop to a new Windows 7 l Using Outlook 3
T Transfer email folders from old pc to new pc Using Outlook 3
S How to transfer Contacts and Calender from Office XP on Old PC to New PC runing Office 2010 Using Outlook 1
S Transfer email group to another computer Using Outlook 13
V How to transfer email in personal folders to another persons computer Using Outlook 9
B Save account and personal settings, and blocked and safe senders for transfer to a new computer or after reinstall Using Outlook 1
E Transfer calendar from a .pst to a user's active exchange account? Using Outlook 7
T Exchange 2007 to 2010 transition, SSL transfer question/problem. Exchange Server Administration 3
