BCM Auto Backup Data and Customizations
shani
Outlook 2013 64 bit
Hello
Is it possible to create a windows task that runs every 3 hours , backups and export BCM data and settings to a file automatically ? I want to Backup all my BCM data and customization on my SDcard/USB every 3 hours.
Or any software/utility that does it ? I found many utility that backup outlook data but cannot find one that does BCM data toO ..
BCM runs in SQL, so you should be able to...
I use a bat file with this in it:
REM Run TSQL Script to backup databases
sqlcmd -S Baloo -E -i"E:\SQLBackUp\scripts\backupDB.sql"
and have that set up in task scheduler. It runs the attached sql file (remove .txt from the filename to use it and change the db name and paths.) ETA: actually, it backs up all db, so you only need to change the path to save.
  • backupdb.sql.txt
shani
Outlook 2013 64 bit
Thank you for the response .. I am getting few error .. Please know that I dont know anything about sql but i am trying to follow as much as i can .. Please check my errors of screen shorts .. and my files .. .. I think i am not able to follow you correctly on backupdb.sql .. please help and guide .. thanks
  • RunScript.txt
  • backupdb.txt
Did you change this to a valid path? ''D:\SQL-BackUp\'
If so, I will need to test it with BCM - there could be other issues that prevent it from working.
shani
Outlook 2013 64 bit
yes i did changed but its not working ):
K Auto-linking emails by default shared DB BCM 2007 on SQL 2008 BCM (Business Contact Manager) 4
Diane Poremsky Restoring BCM Database After Upgrading Windows New Slipstick.com Articles 0
Diane Poremsky Outlook 2016: No BCM New Slipstick.com Articles 0
Diane Poremsky BCM Errors after Upgrading to Windows 10 New Slipstick.com Articles 1
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
