VBA to Forward e-mails from certain address and between certain times
CoffeeMe
I am looking for a VBA code to forward emails from a common mialbox to another address based off of two constraints:
1. if the email came from a certain address
2. if the email came between certain times
Thanks for your help :)
Coffee
H Forward E-mails at Certain Times in Outlook using VBA Outlook VBA and Custom Forms 1
A VBA Script to Forward Spam to AntiSpam Provider Using "Blank" Form Outlook VBA and Custom Forms 2
