Font in Reply is much larger than normal, how to reset ...?
Dave Horne
Outlook 2019 64-bit
Hi, I"m using Outlook 2013 and I don't know what happened, but now all my replies appear as an 18 or so font size.
I've looked at various options in Outlook but can't find how to reset it. Suggestions? Thanks in advance.
Dave Horne
is it the font size or zoom? if the entire message text is larger it's zoom.
To fix zoom: reset the zoom using the zoom button on the ribbon and then close the message - don't send the message.
Screenshots & more information: Adjusting Outlook's Zoom Setting in Email
Font settings are in file, options, stationer and fonts. Screen shots are here:
To Change the Look of Outlook Replies
Dave Horne
Outlook 2019 64-bit
Diane, thanks for your fast response!
When I look at my Signature (which is size 11 in settings) it appears much larger, so I'll assume it's Zoom as you wrote.
This added a few minutes later ...
I used CTRL and the wheel (on my track ball) to adjust it and adjusted it from 140 to 100. So I now have an idea how this issue occurred initially.
Now you mentioned the fact that this is a Zoom issue, I still cannot find that Zoom sliding adjustment. Where is that? Thanks.
:) it's almost always zoom. If there is no slider, there should always be a button to adjust it on the ribbon.
P Outlook 2010 Font on Reply Email is Very Small Ruler Will Not Extend Using Outlook 2
M Why does my font size increases only when I reply to certain people? Using Outlook 3
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
M Message list font changed after update Using Outlook 2
P Message List Font Changed Using Outlook 6
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
D font control by keyboard Using Outlook 2
M font format discrepancies with Quick Parts Using Outlook 1
Steven 2007 New PC vs Old PC - Micro Font on Inbound Emails :( Using Outlook 4
Rupert Dragwater Can't change font size Using Outlook 5
O How to paste website content using a specific font and removing URLs Using Outlook 2
T "From" field font size in table list of emails Using Outlook 0
S Default Font in body of Task Using Outlook 0
Diane Poremsky How to Change the Font used for Outlook's RSS Feeds New Slipstick.com Articles 0
J Increase font size of message body Using Outlook 5
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
J Font size changed in new mail messages Using Outlook 5
Rupert Dragwater unable to change font sizes in some replies Using Outlook 3
D Conditional formatting - font sizes Using Outlook 3
O How to increase Font size in Outlook 2013 Using Outlook 1
Fozzie Bear Change the colour or font of individual email accounts in outlook 2010/13 Using Outlook 1
K Untitled Appointment Font Using Outlook 1
J Change Default View - Color and font Using Outlook 3
J Changing Contact Notes Font Outlook VBA and Custom Forms 9
R Can't modify Outlook view font with IE anymore (even though IE still affects print font) Using Outlook 5
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
O Copy email content and paste into new Word Document using a different font Using Outlook 1
P Outlook 2010 custom form olk control font size increases everytime form is published Outlook VBA and Custom Forms 1
M Default font Using Outlook 2
L Font Type and Space Using Outlook 7
D Default Font in Outlook 2013 Using Outlook 3
F Outlook 2010 custom font style duplicates itself every time I save a task Using Outlook 0
D Point Size for Fonts in Custom Font Style (Outlook 2013) Using Outlook 0
J Microsoft Outlook 2007 Font Size Too Small Using Outlook 1
P Changing all email signatures (font, color) at once in outlook 2007 Using Outlook 2
M Assigning a specific font color to new emails using rules when they arrive Using Outlook 3
