change subject and forward without FW:
Itroit
I'm trying to make a simple rule in OL2016 that will process in outlook, identify certain emails and forward them to a specific address while changing the original subject without FW:
I have this script attached to a rule and it works but when it sends, it adds FW:
Sub ChangeSubjectThenSend()
Dim myolApp As Outlook.Application
Dim aItem As Object
Set myolApp = CreateObject("Outlook.Application")
Set mail = myolApp.ActiveExplorer.CurrentFolder
For Each aItem In mail.Items
aItem.Subject = "OATMEAL"
aItem.Save
Set myForward = aItem.Forward
myForward.Recipients.Add "repository@domain.com"
myForward.Send
Next aItem
Any insight would be greatly appreciated!
Itroit
Thanks for taking the time Diane. Would below be correct in this case? I'm not sure how to edit to your description. Please advise.
Dim aItem As Object
aItem.Save
myForward.subject = aitem.subject
myForward.Send
Next aItem
Itroit
Wait, I think I got it... how's this? seems to work ;)
Dim aItem As Object
aItem.Subject = "AMD"
myForward.Recipients.Add "poattachment@seanet.sea.local"
myForward.Subject = aItem.Subject
myForward.Send
Next aItem
yes, that will work.
if you need to save the original item with the new subject, you may need to add aitem.save - if you only need to change the subject of the forward, you can use myforward.subject = "AMD" and remove the aitem.subject = "amd" line.
V rule to Find some words in the subject, change subject then forward Using Outlook 1
M rule to change subject, pull email addresses from body, and forward with templ Using Outlook 14
C Change Subject Line in Selected Emails Outlook VBA and Custom Forms 1
E Button to change subject Outlook VBA and Custom Forms 1
Aussie I Change the Subject Line ... but after it is moved the subject has reverted Using Outlook 1
P Subject change on selected emails Outlook VBA and Custom Forms 14
A Change a subject after I hit send Using Outlook 1
F VBA Code to change subject Like Outlook VBA and Custom Forms 3
J Change Subject of 500 mails sitting in Outbox with Macro Using Outlook 6
P Automatically 'Reply to all', and Change the Subject of Email - Diane P help! Using Outlook 0
A Change subject line of external software using outlook. Using Outlook 1
L Script to: Change subject of email after checking body Using Outlook 2
J Change the subject line of messages in public folders Using Outlook 3
J Public folders woes (script to change subject line of messages) Exchange Server Administration 0
M Change font of from/to/subject block Using Outlook 1
V Can one change the formatting of email title blocks? Using Outlook 0
S Unable to change Message Class Outlook VBA and Custom Forms 0
C Outlook 365 Can you change the follow up colour? Using Outlook 1
O What would be the recommended way to change an email address (family member)? Using Outlook 0
D Change Microsoft Account password - what to do to update on all devices Using Outlook 4
R How to Change Margins In Google Docs...? Using Outlook 0
D Change senders title Using Outlook 1
E Change sending account depending on Subjectline Outlook VBA and Custom Forms 0
B Change from Address Outlook VBA and Custom Forms 0
X If you change expiration date of repeated task it dupplicates Using Outlook 1
R Folder pane width change Using Outlook 88
