Issue with rules in Outlook 2010
Justo Horrillo
Hello everyone,
I have a strange issue in Outlook 2010 and his rules.
I receive an automatic email from no-reply.face@correo.gob.es every day and this email is flooding my inbox.
I create a rule in the I¡nbox to move this emails to another one, but this is the only rule that not execute automatically, I need to force this rule every moment, to do a clean in Inbox of these emails.
I tried to do this actions without any result:
Add this receiver like a contact.
Try to create that rule in another terminal.
Delete all rules and only create one.
Create one rule with subject.
Repair the OST file with tool SCANPST.EXE
And raised this issue to my colleagues of Servers, but they told me its ok in the Server configuration.
Could you please help me?
thanks in advance.
is there any thing else in the message you can filter on? Are you using 'words in the header' condition, using the address as the word, or a sender is that address rule? Try words in the header...
Justo Horrillo
I tried with words too, but the email resists to move to this folder, (and I used another folder too, but I obtained the same result).
Thanks 4 your help.
It's not uncommon for rules to fail, but it should work at least part of the time if the condition matches.
That's not an NDR is it? Outlook doesn't see them as messages so rules may fail.
A rule with 'no-reply.face@' in the header *should* work - but if it's internally generated on exchange, you won't have a header - if it comes from an outside system, you would.
I'm assuming that adding a category instead of moving fails to?
I have a macro at Move messages CC'd to an address (second macro) that checks all messages for a value and moves them to a new folder. It might work... you'd need to use .SenderEmailAddress = "no-reply.face@ correo.gob.es"
B Forms error - Rules issue? Outlook VBA and Custom Forms 11
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
B Outllok 2007 License Expired issue Using Outlook 0
M Calendar Time Zone issue Using Outlook 0
B My outlook calendar edit issue Outlook VBA and Custom Forms 0
D Unusual calendar issue Exchange Server Administration 0
D Multiple Accounts Issue Receiving Emails in 2016 Using Outlook 0
B Winmail.dat Issue Using Outlook.com accounts in Outlook 0
tswatek Issue with where Outlook saves new contacts Using Outlook 3
K Outlook with MDaemon Connectivity Issue Using Outlook 4
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
D Resizing issue for message field Outlook VBA and Custom Forms 0
P Outlook hanging issue Using Outlook 0
K Outlook 2013 calendar issue with Outlook.com Using Outlook.com accounts in Outlook 2
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
K Insert screenshots issue Using Outlook 2
B Sub Calendar-Color Coding Issue Using Outlook 4
T Using Outlook 2007 with Comcast (.pst inbox issue) Using Outlook 1
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
F Custom contact form icon issue Using Outlook 1
A Autocomplete issue Using Outlook 6
wallisellener Synch issue BCM (Business Contact Manager) 2
H Outlook 2013 size issue Using Outlook 1
C Voting Issue with Shared Inbox Using Outlook 1
J Outlook 2013 Forms Issue Using Outlook 1
A How are you handling Outlook.com category issue and syncing Using Outlook.com accounts in Outlook 2
J Outlook.com EAS Issue Using Outlook.com accounts in Outlook 6
santheocles Issue in Outlook 2013 - cannot reschedule single task Using Outlook 0
P Outlook ruler issue Using Outlook 3
K Different kind of issue related to creation of archive after one has been deleted Exchange Server Administration 1
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
SirFishAlot SIGNATURE EMBED ISSUE OUTLOOK 2013 BCM (Business Contact Manager) 10
J Please help to clarify an IMAP issue Using Outlook 7
S Passive Mailbox database Resynchronization issue Exchange Server Administration 1
J Outlook using colors issue Using Outlook 7
