Delay Send not working
dec1123
Outlook 2007
Periodically my delay send emails Icon will change from the normal SENDING icon to something different
( I think it changes to the DRAFT Icon) when this happens my delay sends do not go out ..then I have to open each and hit send again ..then they go back to the sending mode(Icon) again
help on this would be appreciated Outlook 2010
dec1123
Outlook 2007
I can go into the outbox all day and the messages will not change state....I have been baby sitting this malfunction for some time now and can not identify a pattern or trend...... there have been times I have added another delay send email and they all were in there ready to send then a couple hours later I look in there and they all are marked as drafts..... I resend them and they stay that way for a couple days just fine then out of nowhere they will be changed ...no rhyme or reason
What addins do you have installed? What anytivirus do you use? do you have the reading pane options set to mark as read after xx seconds? (Disable that option.)
K Delay Send and Mail Merge Outlook VBA and Custom Forms 4
G "Delay Delivery" Email fails to send if opened while in Outbox Using Outlook 4
J Diane's Delay Delivery at Specific Times Questions Outlook VBA and Custom Forms 7
T Query About "Delay Delivery" Function Using Outlook 5
S Delay Delivery Macro Outlook VBA and Custom Forms 1
Diane Poremsky Delay Delivery of Messages Sent at Specific Times Using Outlook 0
Diane Poremsky To delay sending a message in Outlook Using Outlook 0
B Macro to delay email Outlook VBA and Custom Forms 0
Diane Poremsky To delay sending a message in Outlook Using Outlook 1
D Delay Delivery: Visible to recipients? Using Outlook 1
Y All emails are received with delay on outlook 2010 Using Outlook 5
M How to forward a message and delay sending for up to 30 days Using Outlook 8
R Long delay for outgoing mail Using Outlook 2
J Rule to Forward email but delay delivery 10 minutes Outlook VBA and Custom Forms 2
C Outlook 2007 Delay Delivery Problem Using Outlook 10
pwatts2 Restrict some lists to only BCC send option Outlook Wishlist 2
F Send As a Gmail account via outlook Web Using Outlook 3
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
M Can't send email in outlook.com Using Outlook 9
R Can't Send calendar share invite Using Outlook 5
