How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed
lorne17
Outlook 2016 64 bit
Hello there,
I am curious how I can get outlook to function the way I had it on my previous computer. I had it setup where it would automatically process Send/Receive every 3 mins in the background. But when I wrote an email and hit send it would not send until that 3 min window. UNLESS (this is the big part I need) I manually pressed "Send/Receive All Folders".
I have looked all over the web for how to set this up the way I used to have it. However, I cannot find a solution. The only thing I can find is to setup a rule to delay message being sent every 3 mins. However, a lot of the time, I want to send it immediately by pressing send receive button. But if I'm using the Rule to "defer delivery" than I can't manually override the send It stays in my outbox. I have to wait those 3 mins.
Does this make sense? I know there's a way, I just can't find out how to set it up again!
Thanks in advance,
Lorne
Soundsl ike you need the send and receive settings - Ctrl+Alt+S or the Send Receive tab, then Send Receive Groups menu - settings s near the bottom of the menu.
Set this setting to 3 min*** and turn off send immediately in Options, Advanced - its near the middle of dialog page
***We actually recommend using not less than 5 minutes.
lorne17
Outlook 2016 64 bit
This is exactly what I needed! Thank you! It was the Options/Advanced step I was missing.
Peter H Williams check for new email automaticlly Using Outlook 12
H 2013 Rules do not run automaticlly on SENT mail Using Outlook 3
glnz O365 - How to send from acct 2 but showing email name from acct 1 as From - alias? Using Outlook 1
F Send As a Gmail account via outlook Web Using Outlook 3
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
M Can't send email in outlook.com Using Outlook 9
R Can't Send calendar share invite Using Outlook 5
R Can't send messages to groups in Outlook Using Outlook 2
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
K Delay Send and Mail Merge Outlook VBA and Custom Forms 4
D Delay Send not working Using Outlook 3
F Send multiple batch tasks to single person Using Outlook 3
R Prompt asking the user to send email to folder as *.msg file Outlook VBA and Custom Forms 1
D Default Send Account that Works? Using Outlook 0
D Outlook.com in Outlook 2016 Trys & Fails to Send on Behalf of Itself Using Outlook.com accounts in Outlook 2
I Outlook 2013 Send mail - it just sticks in Outbox Using Outlook.com accounts in Outlook 0
D send email from Excel using outlook template Outlook VBA and Custom Forms 3
E How to send automatic emails in outlook 2010 Using Outlook 1
