Recent Update Did not Fix Search Problems
MJH 10
Outlook 2013 64 bit
I have been (somewhat) patiently waiting for the Outlook 2016 search problem to resolve itself--as yet it has not. Search appears to work without error messages when searching in a mailbox account or a folder. However, when I search in "All Mail Boxes," I get the following three errors.
! in yellow triangle--Something went wrong and your search couldn't be completed.
These three errors have been appearing for at least the last three weeks. The errors occur on both my desktop setups and all three of my laptops.
Since it has not been corrected by updates, could it me something on my end? I doubt it since it happens on 5 different computers?
Thanks for any suggestions.
it's the June 13 windows update (possibly a few days earlier if using insider builds of either office or windows)- the windows update earlier this week was supposed to have fixed it. You may need to rebuild the index - i didn't and the error is gone.
https://support.microsoft.com/kb/4022716
If you want to go back to the old, slower outlook search, there is a registry key you can set.
MJH 10
Outlook 2013 64 bit
Thanks for your reply Diane.
I have Windows 10. My update history shows KB4022725 06/13/2017. When I ask Windows 10 to check for updates, it says I am up to date. Wondering why it did not install KB4022716 when it checks for updates. Do I click on that update link in your reply to get that update? What other updates could I be missing.
MJH 10
Outlook 2013 64 bit
I probably should include all of the windows updates since i don't know which you are using -
https://support.microsoft.com/kb/4022168 - Windows 7 - June 27, 2017 update
https://support.microsoft.com/kb/4022720 - Windows 8.1 - June 27, 2017 update
https://support.microsoft.com/kb/4022716 - Windows 10 Version 1703 - June 27, 2017 update
They tend to push the updates slowly for the first few days in case anything blows up, leaving fewer victims before they pull it. They usually turn it on 100% after 2 or 3 days, so I'm kind of surprised it wasn't found, but we've just hit the 3 full days point. If you can tolerate the search issues for another day or two, I'd wait it out - otherwise, download and install from the update catalog.
(I have pro and it was installed here on the 28th. )
MJH 10
Outlook 2013 64 bit
Thanks Diane.
Waited through the holiday weekend and checked all my 5 systems this morning, including a W10 Pro version. Still no update (last update on all systems reported as 06/13/17 and check for updates returns your computer is up to date.
A Recent update significantly slowed performance Using Outlook 2
R Preparing to Send hangs Outlook 2007 after recent Windows Update... Using Outlook 5
G Microsoft Outlook 2007 may experience Send/Receive or performance issues after a recent update (KB2412171) has been installed on the computer Using Outlook 2
A Order of Recent Items in Attach File List Using Outlook 5
O See recent emails from a sender Using Outlook 2
M Recent emails disappearing Using Outlook 4
makinmyway Recent Files Not Updating when Using Insert Hyperlink in Outlook 2013 Using Outlook 0
C connecting to recent outlook file on new hard drive Using Outlook 2
D Outlook 2010: Conversations view - most recent activity posts to of inbox? Using Outlook 2
B Having Recent Issues with Hotmail Connector? Using Outlook.com accounts in Outlook 17
A Recent impossibility to send e-mail to some customers using Outlook 2007. Using Outlook 2
A Outlook after recent updates super slow, SPA login does not work. Using Outlook 14
B outlook 2010 Search does not show recent messages Using Outlook 4
T OWA 2007 recent recipients and OWA 2010 nicknames Exchange Server Administration 5
J Sent Items Folder Isn't Showing the Most Recent Sent Items Using Outlook 7
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
Jennifer Murphy Grant R/W (update) access to a friend Using Outlook 3
L Favorites don't update Using Outlook 1
M Message list font changed after update Using Outlook 2
M Quicken One Step Update Bill Reminders Not Syncing to Outlook Using Outlook 1
O Windows 1803 update : QAT and toolbar changed, language pack gone... Using Outlook 5
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
K Update Appointment category when changed in Excel Using Outlook 3
K Update subject based on text in body Outlook VBA and Custom Forms 3
A Creating Progress Bar or Status Bar Update Outlook VBA and Custom Forms 0
R Custom Contact Form how to update when loaded. Outlook VBA and Custom Forms 6
C Update Notes for Meeting Attendees Using Outlook 8
A Attendee Update Outlook Meeting Invite Using Outlook 0
Diane Poremsky Outlook Email Security Update New Slipstick.com Articles 0
S Task Update coming as email and not updating task Using Outlook 3
Diane Poremsky Remove Office 2013 Update Banner New Slipstick.com Articles 0
B IMAP folders don't update when Outlook 365 opens Using Outlook 0
J Outlook Macro to Update Sharepoint Excel File Using Outlook 1
Diane Poremsky Task Request Status Update Address Missing New Slipstick.com Articles 0
Christopher M Importing from Eudora Update Using Outlook 5
Cameron Piper Automatically update custom forms across multiple computers Outlook VBA and Custom Forms 1
M Update field codes when opening Outlook Template Outlook VBA and Custom Forms 2
Bachelle Macro to Update Existing Task from New Email Outlook VBA and Custom Forms 3
I Microsoft Security Update KB3097877 Using Outlook 14
S Outlook 2010: October 2015 Update New Slipstick.com Articles 0
