Just had to reinstall window 10 then Office and forgot how to control fonts sizes
e_a_g_l_e_p_i
As my title says I just installed a new solid start hard drive and a full version of Windows 10 that I bought at the Microsoft Store. I was having problems with my Windows 10 Upgrade for several reasons so I decided to do a fresh install.
It's been a few years since I had to install Office and I am lost with Outlook customizing settings, is there a good tutorial on how to format the fonts for each section of the Outlook interface.
I have figured out somethings but even after I change the font size for something I go back in to settings for example the messages in the main window and the font and size are back to default even though the fonts I changed are still working in the area I changed them.
If there is no tutorials here are my problems,
1. I would like to set the font and size for all messages in all folders to be the same
2. I can't find where to change the font and size of the folders
3. I can't remember how to add spell check to my messages I compose, I once added the spell check to the ribbon but forgot how I did it.
4. I have my messages in the main window set to single but I am getting a second line of part of the message I want to get rid of the mini preview.
Those are the main issues I am having. When someone answers these questions I will save it to my Documents so next time I will not have to ask for help again.
Ron
1. in the message list, set the font size in Views. Disable the Group By View in Outlook - Outlook Tips gives the basic steps - it works for all changes to view, not just group by.
2. Assuming outlook 2010, Tip 894: Changing Folder and Message List Fonts - Outlook Tips 2013/2016 don't have this option and are limited to changing Windows display %.
3. This is in File, options, mail - near the top is spelling and autocorrect.
4. Assuming you see preview for unread messages, this is also in views, under other settings.
e_a_g_l_e_p_i
Thank you very much, You've saved me hours of searching !!
J Office 365 - Online Repair vs. Uninstall Reinstall Using Outlook 1
R Reinstall to a different drive or folder Using Outlook 1
R Cant reinstall POP email account Using Outlook 2
icacream reinstall outlook after new install win7 Using Outlook 2
A Reinstall Using Outlook 1
T Completely wipe all Outlook-related info for reinstall Outlook Wishlist 0
T Completely wipe all Outlook-related info for reinstall Using Outlook 1
T Cas server uninstall failed... Now how to reinstall? Exchange Server Administration 4
M On an Uninstall / Reinstall of Office Professional Plus 2010 Com Add-ins are missing / disabled, Doe Using Outlook 1
K Reinstall Exchange server Exchange Server Administration 2
B Save account and personal settings, and blocked and safe senders for transfer to a new computer or after reinstall Using Outlook 1
2 Lost CONTACT GROUP after Office 2007 reinstall Using Outlook 4
T BCM Install fails Both w Off. Pro 2010 Beta & on reinstall Off.Pro BCM (Business Contact Manager) 5
L Reinstall IIS / Autodiscover virtual directories on an computer running Exchange 2010 server? Exchange Server Administration 6
F Possible to restore/reinstall "special" buttons on custom form? Outlook VBA and Custom Forms 1
J Are the underlined letters in Outlook Reminders window supposed to work? Using Outlook 0
M Outlook email window maximizes improperly Using Outlook 3
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
P Reminders Window stops being displayed, even with /resetfolders or /cleanreminders Using Outlook 8
D Outlook Message Window Changes Size and Position Using Outlook 1
U Catching ModuleSwitch events after "open in new window" Outlook VBA and Custom Forms 2
KURTiS MAXiMUS Trying to appactivate ERP window Outlook VBA and Custom Forms 16
evdbogaard How to dock the Styles Task Pane in the e-mail editing window? Outlook VBA and Custom Forms 1
Diane Poremsky Search for All Messages from Contact and Display in New Window New Slipstick.com Articles 0
V Cannot start Outlook. Cannot open the Outlook window. Using Outlook 8
C Increase Outlook 2013 message window row height Using Outlook 2
M Cannot start MS Office Outlook Cannot open the Outlook window Using Outlook 2
P Item cannot be saved because it was modified by another user or window Using Outlook 8
M Blank Pop-up Window when click "Manage Sharing" BCM (Business Contact Manager) 1
C From an email open a link but not the new window Using Outlook 1
T Constantly Occuring Login Pop-Up Window Using Outlook 1
C Outlook email progress window will not quit Using Outlook 1
F Window minimize automatically Using Outlook 0
A Possible to modify people preview window? Using Outlook 1
C email sending window won't go away even after email has sent Exchange Server Administration 2
B Keeping an Outlook window on top (2010) Using Outlook 6
G How can I identify in VBA if the current window is an item or a folder? Using Outlook 3
A viewing tasks - lower right - in email window Using Outlook 1
N Combobox in outlook add ons toolbar not firing event on main window resized Using Outlook 3
F Open Draft From Compose Window? Using Outlook 8
I Address book contacts not listed in "Select Names:Contacts" window Using Outlook 2
R Sorting and crossing over project tasks in project window (BCM 2010) BCM (Business Contact Manager) 1
E cannot start Microsoft Office Outlook. Cannot open the Outlook Window. Using Outlook 1
R Junk email window automatically minimizes Using Outlook 1
