Display Sender As Contact
I am looking to display the sender of the email in the inbox as a contact. I often get emails from people who text like 9999999@vtext.com. It would be wonderful if I could display the full name of the sender since it is in my contacts.
Please advise.
Outlook uses the display name on the message - but i have a macro that looks up the email address and adds a category, which gets you the lookup part you need. But the display name field is not editable using VBA directly - it might be if you use redemption, otherwise will need to use a custom field or category.
Assign Categories to Messages using Contact Category
Redemption information is here - RDO
(sorry about that - my clipboard wasn't working. :( )
This Finally Worked For Me! Thank you so much. It is amazing to see how much clearer my messages are. I was searching high and low for an answer and this one is amazing. I tried very hard to get this macro to work for days on end, I kept running it without any success changing this field and that field, this column and that column. It always said update done but nothing changed in the email. I guess I didn't realize I had to create a user defined field.
The work and effort you put into the macro is clearly a masterpiece.
Thank youl
J outlook having sort by date or from unable to display sender name. Using Outlook 2
C Why won't Title display in message list? Using Outlook 1
M Daily Task List Minimized Cannot Display Using Outlook 2
C Outlook Mobile app email order randomized and display names stripped Using Outlook 6
N Contact display as Using Outlook 2
J Reminders Display then Disappear Using Outlook 13
O How to display senders email address (column) Using Outlook 1
O How to display number of items per .pst file Using Outlook 7
O Display more months in 'Tasks' Using Outlook 3
O How to display folder icons? Using Outlook 2
Treebys Array out of bounds .display 2016 Outlook VBA and Custom Forms 3
copperberry How to display incomplete tasks due on or before 7 days from now Using Outlook 0
Diane Poremsky Category Color doesn't Display in Inbox New Slipstick.com Articles 0
P How to make outlook display alert appear on top of other windows whenever a new email is received? Outlook VBA and Custom Forms 1
T Outlook 2016 Calendar multiday event display Using Outlook 4
Diane Poremsky Display the Created Date field of any Outlook item New Slipstick.com Articles 0
Diane Poremsky Replace Display Names with Email Addresses New Slipstick.com Articles 0
Diane Poremsky Search for All Messages from Contact and Display in New Window New Slipstick.com Articles 0
O How to display multi-line task in To-Do List - Outlook 2010 Using Outlook 1
Diane Poremsky Display the Recipient Email Address in the Sent Items Folder New Slipstick.com Articles 0
Diane Poremsky Excel Files Won't Display in Reading Pane New Slipstick.com Articles 1
D Display of Open Folders Using Outlook 0
Fozzie Bear Change the Display Name recipients see for Exchange account Exchange Server Administration 0
Diane Poremsky Pictures don't display in Outlook messages New Slipstick.com Articles 4
William Yeack Outlook/Exchange - Changing display of “From” user Using Outlook 3
M Display as name in outlook contacts changes Using Outlook 5
R Coming from Thunderbird: "Always prefer display name over message header" Using Outlook 1
G Wrong display name in from column when removing pf replication Exchange Server Administration 1
J Changing margins in received email display Using Outlook 3
W All Events Disappear from Calendar Display Using Outlook 30
J How to display senders name in inbox Using Outlook 2
R 'Display as' email query Using Outlook 1
Maybear Sudden change in Outlook, no image display, email no longer offers suggestions for address Using Outlook 8
L Messages in old PST display as code Using Outlook 1
C images won't display in email Using Outlook 2
B Display of Sending Account in Outlook 2007 no longer works Using Outlook 2
P Outlook can not display picture inline. Using Outlook 7
O Outlook 2013 contacts - Where to find "Display as"-field Using Outlook 2
