Another reinstall of Outlook 2010 issue
e_a_g_l_e_p_i
Since reinstalling a new SSD hard drive and the full version of Windows 10 I had to reinstall Office 2010. I am having an issue in Outlook where when I search a folder it goes on and on and never produces any results. There is something wrong, in the past when I had to reinstall Outlook 2010 I would save the latest .pst create a new account then copy over the new .pst with my saved .pst. This time I chose my .pst when setting up Outlook and now for the first time my searches do not work. I'm not sure if it is Outlook or somehow related to my new install of Windows 10 but I would appreciate any help in correcting this issue.
Ron
e_a_g_l_e_p_i
yes, my updates are up to date, I tried to go into the search options and rebuild the indexing but nothing seems to fix it. when I search for an email I can clearly see in a folder I get the red wavy line but it doesn't seem to index no matter how long I let it go. ???
e_a_g_l_e_p_i
I'm getting conflicting info, when I look at search options it says "2148 items indexed " but when I search a folder I get the red wavy line and when I click on the details link it says there are 263 left to index but it never finishes ??
e_a_g_l_e_p_i
After my 2nd attempt at rebuilding the index my search now work.
Yeah, after the bad updates are fixed, you almost always need to re-index.
Malcolm1935
There are issues with search in window 10. Are all windows updates installed?
Ii am a brand new member and cant find a box where I can ask you about my WIN10 pro, 64 bit, outlook 2010 and error message 'this operation has been cancelled' etc.
This happened after I uninstalled Firefox after a suspect message purporting to come from microsoft requesting details.
Please direct me as to how to provide you all the details.
Thank you,
Malcolm
henryth
Outlook 2019 64-bit
Very ridiculous to appearing such kind technical error again and again over a period of time firefox critical error occurred I suffered a lot finally, I got the solution through the mentioned link, by the way, if it is not founded then I have to suffer continuously on this topic, the developer needs to improve a lot, if they want satisfied user they have to provide good browsing quality and experience.
R Time for another article on contact cards? Using Outlook 0
M Moving mail to another folder is much slower than before (Office365) Using Outlook 0
B Moving account, contacts & emails to another H/D with MSOutlook Using Outlook 5
M Shortcut to another outlook item Using Outlook 0
M FW Email via Outlook and another requirement Outlook VBA and Custom Forms 1
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
Diane Poremsky Copy New Appointments to Another Calendar using VBA New Slipstick.com Articles 0
D Unable to Send On Behalf of Another User Exchange Server Administration 0
D EXPORTING MS EXCHANGE EMAILS to another platform Exchange Server Administration 10
mrmmickle1 UserProperties VBA to move message to another folder Outlook VBA and Custom Forms 7
P Office 365 manage another person's calendar Using Outlook 0
TheDavidSlight Daylight savings - another subtle bug ... Using Outlook 3
C Custom Application Form send Email to Another User Using Outlook 1
A Calling one module from another Outlook VBA and Custom Forms 2
M How to duplicate content of one field in another field? Outlook VBA and Custom Forms 3
iwshim Transfering mail from the outbox to another computer Using Outlook 0
I Outlook 2010 Replicating mixed PST/OST profile to another desktop Using Outlook.com accounts in Outlook 1
J Macro for replying to One Email with another Using Outlook 1
wallisellener Another BCM Authentication thread BCM (Business Contact Manager) 5
mikecox Forward email to another address; not with Rules Using Outlook 3
T Macro to find contacts by category and copy them to another folder Outlook VBA and Custom Forms 15
I How to block time in another calendar without invite? Using Outlook 2
Paul Butticaz Copying Contacts from SharePoint List (connected to Outlook) to another Conacts folder Using Outlook 1
P Item cannot be saved because it was modified by another user or window Using Outlook 8
Klaas "To Address" duplicated when moving msg to another folder Using Outlook 2
Britonius Delegate cannot view meetings marked Private by Another Chairperson Using Outlook 7
P Macros in Word 2003 - how to transfer to another Word 2003? Using Outlook 1
F Adding User Defined Field to another form Using Outlook 0
D Cancelled Meeting Notifications to another mail address Outlook VBA and Custom Forms 1
M Print Attachments from another mailbox (not default) Outlook VBA and Custom Forms 2
L Move E-Mails to Another Folder Using Outlook 66
