Archiving Problems
David_H
My Outlook 2016 ost mailbox was about 15 GB so today I tried to archive everything from 2010 - 2016 to a pst file, using the built in tool (File > Tools ?\> Clean Up Old Items). I havetwo questions:
1. When I look at "folder size" within Outlook, it now shows about 1Gb, which is about what I'd expect. But if I look at the ost file (app data > local > microsoft> outlook), the ost file is still 115 GB. Why? I closed and restarted, still the same size.
2. In several folders it left old messages going back years and didn't archive them. Is there any way for me to have it do another run and catch the old messages and archive them to the SAME pst folder with the folder structure intact? I can try to do it manually but that will waste a lot of time.
1. You need to compact it. Outlook will work on it as the computer is idle, but you can start compacting and head to lunch. It will probably take a few hours, but you can stop and start it as needed. See How to compact an Outlook data file (*.pst) if you don't know how to compact.
Sorry about missing #2... I have a problem with clicking Post before i'm finished. :(
On 2, it depends on why they were missed - are they marked to not be archived or did you do something to change the last modified date?
See AutoArchiving by Received Date in Outlook for a registry key to archive by received date.
David_H
Thanks for your response. Neither on #2, but I just ended up transferring them manually. Unfortunately going from a 15 gb file to a 500 MB files doesn't seem to have made a bit of difference with regard to Outlook hanging and being slow. Which is pretty much something I just live with as a fact of life when it comes to Outlook, but since I'm always told it's due to file size I figured I'd give it a try. It's the only program that is always slow, whether I'm on my desktop or laptop, both of which are high powered machines :-(.
At 15 GB, it could be the data file size, but the number of messages in the inbox (because its the folder you use the most) can also cause it to be less responsive, but only if you more than like 5000 or so. This is due to outlook displaying the messages in the view.
What type of email account do you use? Do you have any/many addins installed?
Outlook will be slower on computers with less ram - but if you have more than 8 GB, it shouldn't be a factor most of the time - even 4 GB should be ok unless you are doing a lot of intensive work in other programs.
David_H
Thanks Diane. I think I spoke too soon. It has definitely sped up very significantly, though at times it does still hang when switching between different views/folders.
I use multiple Exchange mailboxes on O365. I suspect having multiple mailboxes might be part of the issue. But now that it's improved significantly I'm going to watch closely and try to diagnoses the cause of any remaining problems. It's not the machines that's for sure, the laptop has 16 GB of RAM and the desktop has either 32 or 64, can't remember which.
One other thing I suspect is OL has some issues running at native 4K (no scaling of any type). I've had many instances where it starts to freak out, and if I minimize it to a smaller size suddenly responds instantly. I believe this is an OL issue because I don't encounter it with any other programs. I can run much more memory intensive programs like AutoCAD at native 4K with never a hiccup.
Anyhow, thanks for your help as always :). I'm happy at the improvement I'm seeing here.
Possibly. I know there are issues if the scaling is set too high (over 125 or 150%)
I have 4 Office 365 Exchange + 2 shared mailboxes autpmapped & 2 sharepoint mailboxes. I don't have problems, at least not on my desktop (32 gb). It's slower on my 8 GB 2-in-1 but it could just be my frustration - i get annoyed with the 11" screen and small keyboard.
O Calander archiving problems Using Outlook 4
P Problems archiving emails Using Outlook 3
P Manual Archiving 2016 Using Outlook 7
L Calendar archiving policy Exchange Server Administration 1
R Archiving into 1 archiving folder only Using Outlook 4
CWM030 Archiving ON the imap server Using Outlook 3
GaryW88 2016 Archiving IMAP keeping mail on Gmail Server Using Outlook 1
G Outlook 2016 Archiving Outlook VBA and Custom Forms 1
Diane Poremsky Archiving Tools for Exchange Server New Slipstick.com Articles 4
J Search and In-Place Archiving Using Outlook 0
M Archiving by year Using Outlook 1
Fozzie Bear Wishlist A built in Archiving system that allowed storage of messages on a normal file server Outlook Wishlist 1
J Opening/Archiving/Import/Export PST files Using Outlook 4
T BCM 2010 Archiving Communication History BCM (Business Contact Manager) 2
J Joint mail folders over network and archiving Using Outlook 1
gemini9189 Archiving Emails Into Folders Using Outlook 1
V Archiving Sent Items Using Outlook 1
B Archiving of emails doesn't work anymore Using Outlook 3
Z Outlook and gmail, cloud storage and archiving Using Outlook 2
L Save vs Archiving Using Outlook 0
J archiving deleted e-mails on Microsoft Exchange Exchange Server Administration 7
Fozzie Bear Archiving Emails Using Outlook 2
S Previously flagged messages not archiving Using Outlook 3
V Archiving & IMAP Using Outlook 4
B archiving outlook 2010 Using Outlook 6
H Archiving problem in OL 2003 Using Outlook 5
D Outlook Archiving sent emails which have been moved to inbox folders Using Outlook 1
B Outlook Calendar Archiving Using Outlook 1
N Archiving folders outside of Outlook to reduce PST file size Using Outlook 2
F archiving - not working Using Outlook 1
K Archiving function Using Outlook 1
D Archiving in Outlook 2007 - Archiving tab has completely disappeared in File menu. How do I get it back. Using Outlook 2
H Have lost 'buttons/word clicks' for archiving data Using Outlook 1
P Archiving function and menu item disappeared in Outlook 2007 Using Outlook 2
J I don't appear to have archiving in Outlook 2007 Using Outlook 2
D Personal Archiving Based on Mailbox Quota Exchange Server Administration 2
A Archiving with SP1 Exchange Server Administration 1
S Exchange 2010 Archiving and Outlook 2007 Exchange Server Administration 12
D Outlook 2003 Archiving Outlook VBA and Custom Forms 2
M Archiving Outlook Wishlist 0
J how do I accomplish offline archiving of email? Outlook VBA and Custom Forms 1
U "archive.pst cannot be opened" when archiving Using Outlook 4
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 2
