query outlook using vba
Bruce Jackson
Is it possible to search outlook using a query in a vba script .I have a 3 calendars set up where I write to outlook and insert delivery job numbers and some information pertaining to the job as appointments
I would like to clear the calendar of that job number entry once the delivery has been made
I currently use
For Each oObject In oFolder.Items ,which checks each item of outlook to see if the particular job number exists
and if it does it clears the entry
the problem with that method is as each day passes the script takes longer and longer to execute
I need some way to query outlook,to cut down on checking every single item
Below is the method i use to find and delete travel times from old appt. i'm not sure its any faster to use count over for each... but when i run (usually monthly), i need to delete 30 or 40 old events. (Will need to test it again one using find)
what you need to use is find or restrict - one sample is here How to print a list of recurring dates using VBA
Sub BlockedTimeDelete()
    Dim objNamespace As Outlook.NameSpace
    Dim objSourceFolder As Outlook.MAPIFolder
    Dim objVariant As Variant
    Dim lngMovedItems As Long
    Dim intCount As Integer
    Set objOutlook = Application
    Set objNamespace = objOutlook.GetNamespace("MAPI")
    Set objSourceFolder = objNamespace.GetDefaultFolder(olFolderCalendar)
    For intCount = objSourceFolder.Items.Count To 1 Step -1
        Set objVariant = objSourceFolder.Items.Item(intCount)
        DoEvents
        If objVariant.Subject = "Travel Time" Or objVariant.Subject = "Meeting Review Time" Then
            If objVariant.Start < Now Then
              objVariant.Delete
              'count the # of items moved
               lngMovedItems = lngMovedItems + 1
    ' Display the number of items that were moved.
    MsgBox "Moved " & lngMovedItems & " messages(s)."
This is faster - i need it to delete one of two subjects and will need to work on that, but for single subjects it is faster.
Sub DeleteBlockedTime()
   Dim CalFolder As Outlook.MAPIFolder
   Dim CalItems As Outlook.Items
   Dim ResItems As Outlook.Items
   Dim sFilter, strSubject, strOccur As String
   Dim iNumRestricted As Integer
   Dim itm, ListAppt As Object
   Dim tStart, tEnd As Date
   ' Use the selected calendar folder
   Set CalFolder = Application.ActiveExplorer.CurrentFolder
   Set CalItems = CalFolder.Items
   ' Sort all of the appointments based on the start time
   CalItems.Sort "[Start]"
   CalItems.IncludeRecurrences = True
   ' Set an end date
    tEnd = Format(Now, "Short Date")
    strSubject = "Travel Time"
   'create the Restrict filter by day and recurrence
   sFilter = "[End] < '" & tEnd & "' And [Subject] = " & strSubject
Debug.Print sFilter
   Set ResItems = CalItems.Restrict(sFilter)
   iNumRestricted = 0
   'Loop through the items in the collection.
   For Each itm In ResItems
      iNumRestricted = iNumRestricted + 1
      itm.Delete
   Set itm = Nothing
   Set ListAppt = Nothing
   Set ResItems = Nothing
   Set CalItems = Nothing
   Set CalFolder = Nothing
Bruce Jackson
Thanks Diane
if I understand this correctly-that gets all items between dates,then loops through each item checking for the string value passed ?
where did you set your tStart in this code and how would the sfilter look with the tStart
Thanks for your help
This sorts the calendar by date (in a hidden list view) and then looks for events matching the filter conditions- in my case, looking for the end date and subject. If it finds it, the item is deleted.
Note that if you are deleting more than one item, it will skip some - as many as every other one - because it "loses count" when you delete items and it moves forward (if you have 4 items and delete # 1, outlook moves to #2, which was previously #3). In my tests with 8 travel and review events, it skipped one or two when i used case statements and ran the filter twice, but 4 when i put both subjects in the same filter. The first macro steps backward so the count isn't affected.
I'm only checking the end date (which is the same as the start date for one day events, which all are so it doesn't make a difference here...). if you need to check the start date, you'd basically copy the tEnd code and change it to tStart. Or since the only place that Start or End really matters is in the filter, you could just change [End] to [Start]. If you need to check both start and end, you'd add [Start] < '" & tStart & to the filter (with the proper # of " and ')
Bruce Jackson
Thanks Diane
I am not sure about the losing count- I loop through a recordset in an access db and delete one record in outlook for each loop in the database.when I first started it took outlook maybe a few secs per record,and all up maybe 1 minute for the script to complete
now-its 10mins and rising,which is not sustainable
thanks again
I will experiment a bit-and see how I go
it should work fine for you if its one item per loop. I don't know if it would be much faster, but if outlook could get an array of the search terms, it might be faster to run everything in Outlook. Using an array rather than reading the access data base over and over would be faster too.
Bruce Jackson
I could pass a string array to outlook-delimted by what ever outlook would recognise
of course to build the array would require looping through the recordset-but that happens very quickly using vba within access.
what how would I pass that to outlook to process
The problem isn't how fast Access does it, it's that Outlook needs to keep reading it (or Access needs to keep going back to Outlook). If you can read the db once, it eliminates one step that gets repeated many times.
This page is not a really good example because it uses an array in the macro - i'll see if i can find an example from reading a file -
once the array is in the variant in memory, you do roll through the array doing whatever....
For i = LBound(arrSubject) To UBound(arrSubject)
sFilter = "[End] < '" & tEnd & "' And [Subject] = " & arrSubject(i)
Debug.Print sFilter
iNumRestricted = 0
itm.Delete
Next i
Bruce Jackson
heres the sub I use
Public Sub DeleteScheduledJob(ByVal argSubject As String, MailName As String)
'the job number I delete is supplied in argSubject
Dim OApp As Object
Dim oNameSpace As Object
Dim oApptItem As Object
Dim oFolder As Object
Dim oMeetingoApptItem As Object
Dim oObject As Object
Dim sErrorMessage As String
' check if Outlook is running
Set OApp = CreateObject("Outlook.Application")
On Error GoTo Err_Handler
Set oNameSpace = OApp.GetNamespace("MAPI")
Set oFolder = GetFolderPath(MailName & "\Calendar")
If oObject.Class = olAppointment Then
Set oApptItem = oObject
If InStr(oApptItem.Subject, argSubject) > 0 Then
oApptItem.Delete
Next oObject
Set OApp = Nothing
Set oNameSpace = Nothing
Set oApptItem = Nothing
Set oFolder = Nothing
Set oObject = Nothing
Set oMeetingoApptItem = Nothing
Err_Handler:
sErrorMessage = Err.Number & " " & Err.Description
I could add another argument to the sub containing the string array built in the calling sub
just not sure what I need to do to use that array
Bruce Jackson
this is how I could supply a comma delimted array of job numbers to delete
dim myarray
myarray=split(argSubject,",")
from here I am lost as to how to use the array
hope this is making sense to you
again-thanks for the help
on the macro - are you the only user? it might speed it up a little to use early binding to the outlook object model. late binding is easier when you are sharing it with others.
Something like this should work -
For i = LBound(myarray) To UBound(myarray)
sFilter = "[End] < '" & tEnd & "' And [Subject] = " & myarray(i)
Debug.Print sFilter
iNumRestricted = 0
itm.Delete
Next i
Bruce Jackson
unfortunately I need to use late binding as it has several users and I can never be sure what version of outlook they use
I will give it a try and see how I go
I got the guy who looks after outlook 365 for this company to clean up and archive outlook items
hes also set up some automatic archiving(whatever that means)-and the script is back running fast (delete 40 entries in maybe 10 secs)
I don't understand the outlook model -its methods and propertys,and what you can or cant do -so it will be trial and error for me
Regards
Yeah, in that case you definitely need late binding.
It sounds like the problem was due, in part, to so many items to search though.
C Outlook local calendar & iCloud calendar syncing query Using Outlook 3
D outlook 2003/2007 macro query Using Outlook 2
B Select / activate first email item in the searched query Using Outlook 1
Q Mail account setup query Using Outlook 0
T Query About "Delay Delivery" Function Using Outlook 5
S Subject add ticket number from URL query Outlook VBA and Custom Forms 2
P Calendar permissions query Using Outlook 1
R 'Display as' email query Using Outlook 1
C 'Show as conversation' query Using Outlook 0
C Unusual Signature & Spell Check Query Using Outlook 1
J Rule Category Conditions Query Outlook VBA and Custom Forms 1
J Opening an existing message from a database query Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 6
J outlook 2007 doesn't let me choose which .pst to search Using Outlook 0
D Connecting Gmail to Outlook 365 - My Setup not working Using Outlook 1
K Outlook tasks formatting Using Outlook 4
G Retention Policy for Outlook.com Deleted Items folder Using Outlook 0
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
H I have no profile listed for Outlook! Using Outlook 9
D Outlook 2016 how to use gmail account as source account for outlook 365 Using Outlook 9
Horsepower Contacts added from iPhone don't show up in Outlook Using Outlook 1
A Outlook (and Office) 2019 Logging Using Outlook 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
L Outlook saved template function too limited Using Outlook 2
M Outlook on 3 Computers Shows Different Total Items on Same Account Using Outlook 3
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
witzker Open Contact missing in Outlook 2019 Using Outlook 2
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
M outlook 365 trying to finish my sentences Using Outlook 0
D Outlook Address Book Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 5
