Outlook 2016 Not Default Client
patlaw
Every time I reboot my computer and start Outlook 2016 for the first time, I get this error message. I've researched extensively to find the problem, but nothing I've done matters. The problem has been there since Day One of the installation. Outlook 2016 is the 32-bit version on a Windows 7 Professional 64-bit operating system. No other email client is installed on the system, including Thunderbird, which seems to cause problems. Suggestions? Thanks!
patlaw
It's troubling that 57 people have viewed this post so far, and no one has any suggestions. Obviously this problem is not very widespread.
No, it's not widespread... i actually haven't seen this problem in a couple of years, and it was usually associated with a 3rd party application that used outlook but couldn't find it.
What is listed in the registry for these keys?
HKEY_CURRENT_USER\Software\Clients\Mail
HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Mail
HKCU value should override the one one in HKLM, which is used for new users or if HKCU is empty.
My HKLM has
"PreFirstRun"="Either there is no default mail client or the current mail client cannot fulfill the messaging request. Please run Microsoft Outlook and set it as the default mail client.*Microsoft Office Outlook"
@="Microsoft Outlook"
while HKCU has only
if you untick 'perform this check', does another program try to take over as default? Does it cause any other issues?
patlaw
Hi, Diane. Thanks for taking the time to try to help.
My HKLM has Microsoft Outlook, Windows Mail, and Windows Live Mail.
My HKLM has
while HKCU has only
My HKCU has only "Microsoft Outlook".
I haven't tried that, but I will. Maybe that step will point to the offender.
R Making Outlook default client in share charm Using Outlook 4
C Either there is no default mail client or the current mail client cannot ... Using Outlook 1
T Make Default Outlook 2010 Client Mail Using Outlook 1
V Accepted meetings do not get the default reminder Using Outlook 0
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 3
O How come default profile changed? Using Outlook 2
T Outlook changes default account Using Outlook 1
V VBA when replying + Default Account Using Outlook 2
P Outlook.com account overrules default account Using Outlook.com accounts in Outlook 8
D Add all meeting rooms to the meeting request by default Outlook VBA and Custom Forms 0
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 5
Mark White VBScript Move sent mail to non-default folder Outlook VBA and Custom Forms 0
N How to delete default folder "Contacts" (olFolderContacts) in a .pst file Using Outlook 8
D Default Send Account that Works? Using Outlook 0
T Changing default Mail Account in Outlook 2016 - POP3 Using Outlook 1
J Setting default address book Using Outlook 0
C Change default colors for conditional formatting Using Outlook 2
S Default Font in body of Task Using Outlook 0
Diane Poremsky Set Another Data File as Default When Using an Exchange Account New Slipstick.com Articles 0
Diane Poremsky Shared Mailboxes and the Default 'Send From' Account New Slipstick.com Articles 0
Diane Poremsky Working with VBA and non-default Outlook Folders New Slipstick.com Articles 0
Diane Poremsky To Change the Default E-mail Program in Windows New Slipstick.com Articles 0
C Delete Subject-Add Organizer to all Reservations in Default Calendar. Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts New Slipstick.com Articles 0
B Outlook 2016: Can't delete default calendar but I don't use it Using Outlook 7
B Calendar shows too much info by default Using Outlook 0
M Default Calendar Using Outlook 0
L Change default from english to danish ...... Using Outlook 5
Diane Poremsky Changing the default *.pst and *.ost sizes New Slipstick.com Articles 0
