Keep Original html body when forwarding an email
DAVID POWELL
This code is wiping out my original mail with text and html
I want to retain the original message and just add something at the top ?
add this : "This is Rejected"
Sub CommandButton6_click()
ChangeSubjectForward Item
End sub
Sub ChangeSubjectForward(Item)
Item.Subject = "Test"
Set myForward = Item.Forward
myForward.Recipients.Add "ccccc.ccccell@somewhere.com"
myForward.Body = "This is Rejected"
Item.Save
myForward.Send
david powell
DAVID POWELL
myForward.Recipients.Add "test@domain.com"
myForward.HTMLBody = "This is Rejected" & myForward.htmlbody
myForward.Send
This seems to work
is there another way ?
David Powell
That is the easiest, most efficient way... you could use word vba to insert text before - an example code is here - Add Attachment Names to Message Before Sending
it's an additional 10 lines - i would probably only use it in your situation if the html body gets messed by the additional code. if you need an extra line between the text and the original body, try using either html tags or adding vbcrlf.
DAVID POWELL
Actually yes, i'm needing an extra line after:
Because I want it to read:
This is rejected
Blah blah blah blah
html stuff
Try using
myForward.HTMLBody = "<p>This is Rejected</p>" & myForward.HTMLBody
The sample with more space used the p tags, the top one is using your initial code. Using 2 <br /> tags is the same as using the p tags:
myForward.HTMLBody = "This is Rejected <br /><br />" & myForward.HTMLBody
BTW, you can use html styles too - just use single quote, not double, with style:
myForward.HTMLBody = "<p style='color:red; font-size:18pt'>This is Rejected. </p><p>Try again. </p>" & myForward.HTMLBody
DAVID POWELL
this worked:
eBody = "I Have Reviewed and Approved the following pricing escalation." & "<br>" _
& "Please Review the Request and advise if you support the links below." & "<br>" _
Thanks for direction
dp
P Want to keep original .pst file as main email file after upgrading to Outlook 2010 Using Outlook 1
R keep track of the original sender Outlook VBA and Custom Forms 3
CWM030 Outlook 2016 with imap emails keep Resurrecting themselves? Using Outlook 5
O Wishlist Native solution to detach attachments but keep a link to them Outlook Wishlist 1
Scorpion New Contacts keep coming up as company Using Outlook 1
R Can't keep emails synced on various devices Using Outlook.com accounts in Outlook 4
piusg 2013: Task Views keep disappearing Using Outlook 4
Dan Badur How can I keep indenting OFF on replies in Outlook 2013? Using Outlook 1
S how to keep "To" when move sent emails to other folder Using Outlook 1
K Deleted emails keep coming back Using Outlook 3
A How to add personal notes to a meeting - and keep them if update sent? Using Outlook 1
A outlook trying to keep sending Using Outlook 1
B Closing Exchange service, how to keep all calendar and mail data? Exchange Server Administration 0
D How to keep Outlook 7 open to full screen Using Outlook 2
S How do I keep my old PST file as default Exchange Server Administration 1
Z Keep Unread Messages in same folder Using Outlook 2
L Oulook always "disconnected" how do I keep it open all of the time? Using Outlook 1
P emails with attachments keep sending... HELP!!! Using Outlook 4
M How do you keep sent emails in the PST folder in outlook 2013 Using Outlook 1
N Contact Groups - names keep changing from Contacts to AddressBook Using Outlook 5
M Reminders keep coming to users' calendar Exchange Server Administration 1
L Outlook 2010 - Keep getting "Corrupted File" Msgs Using Outlook 4
S Reminders keep popping up, even after dismissing them Using Outlook 9
P deleted items keep reappearing in my deleted folder Using Outlook 4
P Stationary and view layout keep changing after reboot? Using Outlook 1
D Users changing domains within a corp, but need to keep old address. Using Outlook 2
C Keep personal maps structure when reopening OUTLOOK 2010 Using Outlook 1
A How to keep email in bold in OL 2010 Using Outlook 3
G Outlook keep prompt for log in credential Using Outlook 1
W Outlook 2010: Need to keep restarting outlook to download mail from a MAPI server Using Outlook 4
N Exchange 2010 RPC Over HTTPS, outlook keep trying port 135 Exchange Server Administration 9
S I keep getting a not responding message and a gray screen__when i change folders Using Outlook 3
C I want to KEEP ALL CALENDAR ITEMS FOREVER. Using Outlook 1
Y MICROSOFT OUTLOOK 2007 - i KEEP GETTING THE "ENTER NETWORK PASSWORD" BOX POPPING UP - IT IS ALREADY Using Outlook 4
R Pop up window keeps appearing telling me to enter my user name and password. Doing so does not make the windows go away, they just keep coming back. Using Outlook 1
R hosting a single domain name, but keep all users 'seperate' Exchange Server Administration 3
A Despite Windows Live Hotmail working as desired, I keep getting a message about 'Can't sign in' or Can't connect. This is the same with Outl Using Outlook 3
