Outlook 2016: /altvba startup switch does not work
Denis Repke
I am trying to use the Outlook 2016 command line switch "/altvba <VbaProject.otm path>" to start Outlook with its "VbaProject.OTM" macro file in a non-standard location instead of "%appdata%\Microsoft\Outlook", but it does NOT work. I have used this switch successfully in previous versions of Outlook, and it is supposed to work in Outlook 2016 but when I try to use it, I receive an error message that this switch is not valid. Any help in resolving this issue would be greatly appreciated. Thank you.
Denis Repke
Thanks for the info. I hadn't been able to find any information that a registry entry was needed for Outlook 2016 (only found info for Outlook 2013). I added the EnableAltVba key and it works now. Thank you.
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 5
M Office 2016 Outlook is forgetting passwords Using Outlook 15
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
A Outlook 2016 in Cached Mode Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
GregS Outlook 2016 Outlook 2016 stalls Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
K Outlook 2016 Using Outlook 0
W Search Incomplete Outlook 2016 Using Outlook 5
A Outlook 2016 not synching Using Outlook 4
B The Outlook 2016 Profile that isn't always there Using Outlook 2
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
J Checkboxes when selected will appear in a textbox in Outlook 2016 Outlook VBA and Custom Forms 1
N Outlook 2016 Address Book lookup Using Outlook 9
D Outlook 2016 automatically increment anniversaries Using Outlook 1
