HOW DO I FORWARD AN EMAIL WITH MACRO using an email that in the body of another email
Sabastian Samuel
Outlook 2016 64 bit
I WOULD REALLY APPRECIATE IT IF SOMEONE COULD HELP ME OUT. IVE BEEN TRYING TO UNDERSTAND MACRO LANGUAGE FOR AGES AND I CANT SEEM TO GET ANYWHERE!
HERE IS WHAT I WANT TO DO. I hope this makes sense.
I want a macro to read every email that gets sent to my inbox.
IF the subject line begins with "Lost Property at"
THEN extract the whole body of the email as a string - string name "BODY"
SPLIT the the string at the point where "\split" is in the text
I should have these strings only now
BODY_1
BODY_2
i dont think there is a chance of \split being in the body more than once. but if it is, i would want to isolate BODY_1 and concatenate the rest together
I now want the macro to write an email:
to: BODY_1
subject
: the subject of the original email
body: BODY_2
SEND
you can use it either in a run a script rule or watch the folder and process it using an itemadd macro.
Outlook's Rules and Alerts: Run a Script
How to use an ItemAdd Macro
this snippet will do what you need (i think the array code is correct, but it might need tweaked)-
if lcase(item.subject) = "lost property" then
Dim BodyArray() As variant
BodyArray() = (item.body, "\split", 2)
--create new message --
Create a new Outlook message using VBA
then use this:
newMsg.to = bodyarray(1)
newMsg.body = bodyarray(2)
newMsg.send
end if
Sabastian Samuel
Outlook 2016 64 bit
There is an error on BodyArray() = (item.body, "\split", 2)
you need to set the item object to a message - this will use the selected message (great for testing - change it to use incoming messages later)
sub lostpropertyforward()
Set Item = application.ActiveExplorer.Selection.Item(1)
' rest of your code
end sub
W Macro to forward email Outlook VBA and Custom Forms 2
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
D How to forward each email x minutes after it arrives in inbox and hasn't been moved or deleted? Using Outlook 1
mikecox Forward email to another address; not with Rules Using Outlook 3
D forward email with attachment using .oft Using Outlook 3
R Auto-create receipt from email and forward to payer Using Outlook 3
C Unable to forward email with URL Using Outlook 2
M rule to change subject, pull email addresses from body, and forward with templ Using Outlook 14
A Outlook 2010 - Want to Have All Email Reply Forward as Rich Test Using Outlook 7
P email arrows - respond and forward Using Outlook 1
L Forward Email and Insert Sender's Email address in body Outlook VBA and Custom Forms 3
M Forward email as insert from button Outlook VBA and Custom Forms 1
J Rule to Forward email but delay delivery 10 minutes Outlook VBA and Custom Forms 2
S forward email Outlook VBA and Custom Forms 1
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
D Forward message to address from subject Outlook VBA and Custom Forms 1
J How to change From then forward message Outlook VBA and Custom Forms 1
S Reply & Forward Date in original message incorrect Using Outlook 2
