Remove Old Location From Tasks Pane
Tomohawk
I'm using Outlook 2016. Some time ago, I changed my e-mail account from Yahoo to Outlook. I use POP3 (.pst files). At that time I simply moved all my tasks (I think I simply did a drag and drop, or a cut and paste) from my Yahoo to my Outlook.
When I now go to my Tasks view, I can still see my old repository in the pane (see attached), but it is empty. Is there any way this can be removed?
if you go to the folder list (ctrl+6 or the folder icon at the bottom of the navigation pane), is there a task folder under the yahoo data file? right click on it and see if Delete folder is enabled. if so, delete it, if not, the data file was set as default at one time and you'll need to use mfcmapi to delete it.
B How to remove an old program from the Tools dropdown? Using Outlook 7
C Remove old form-folder-entries from List Using Outlook 5
V Remove old recipients before forwarding Outlook VBA and Custom Forms 1
E Remove flag automatically Using Outlook 4
Timmon Remove just one attachment before AutoForward Outlook VBA and Custom Forms 0
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
O Remove duplicates within two accounts Using Outlook 2
D How to remove a folder, option grayed out Using Outlook 4
B Remove Subject Residual Outlook VBA and Custom Forms 3
R Chancing / remove “ something ” in the subject, online archive Outlook VBA and Custom Forms 8
Morgan Fowler Remove Signature Using Outlook 1
M VBA to remove deferred delivery on a MeetingItem Outlook VBA and Custom Forms 2
J Remove extra line above signature in reply Outlook VBA and Custom Forms 5
Diane Poremsky How to Remove RSS Support from Outlook Using Outlook 0
Diane Poremsky Remove Attachments From Messages Using Outlook 0
Diane Poremsky Remove Office 2013 Update Banner Using Outlook 0
O Remove duplicate mail items Outlook VBA and Custom Forms 6
Diane Poremsky Remove a password from an Outlook *.pst File Using Outlook 3
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
J Your IMAP server wants to alert you to the following: cannot remove system folder Using Outlook 3
C how to remove icons on right hand side outlook 2013 Using Outlook 2
K Remove Manage APPS button for users Exchange Server Administration 1
P Remove name and parenthses from email Using Outlook 1
G Outlook calendar entry corrupted. Constant pop up when you open outlook. Unable to delete or remove. Using Outlook 2
Diane Poremsky How to remove the primary account from Outlook 2010/2013 Using Outlook 0
Diane Poremsky Remove an Address from Reply All Using Outlook 0
Diane Poremsky Remove Outlook apps from Outlook Using Outlook 0
S How to remove forms from Organizational forms library Outlook VBA and Custom Forms 2
2 Task has a strike through but is not complete - how to remove? Using Outlook 1
