When I add more search strings to RULES, it is not processing them
Bruce Johnson
I am trying to create rules that process spam and I have built up a list of different strings and have been adding the to a rule.
Now when I add more strings, it does not process the new strings. I thought, ok, there might be a max, so I create a NEW rule to add the new strings to, but it is not processing them.
Any ideas?
Bruce
how many rules do you have? POP3 supports a lot of rules, Outlook.com & Exchange, not as many - less than 100 if the rules have a lot of conditions.
it's more likely that outlook can't find the string. spammers can be tricky and use HTML tags to hide the strings - rules look at the raw body, not what you see on the screen.
or... its a problem with the rules engine. The junk mail filtering function has been messed up from updates this summer, its possible that has also affected rules.
Bruce Johnson
I can put the same string in the search bar and it finds it.... I have deleted a bunch of old rules trying to resolve this, but I still have a lot (80)
80 is a lot, but i don't think its too much... (that many is hard to manage, but that's a different problem)
where in the list is the 'bad' rule? Try moving it to the top of the list. (The ones that apply to more messages should be on top.)
Do you use Stop processing? This is recommended - as soon as a message meets the conditions, it is processed and the rest of the rules aren't checked against it. Outlook moves on to the next message. This, along with the rules order, makes it more efficient for outlook, especially with a heavy load of mail and lots of rules. If outlook has a lot of messages to process, it may skip processing some to clear the backlog.
How many different phrases are in the rule?
How many messages come in with each mail check?
do you use any of the built in junk mail filtering? That could help lighten the load on rules.
B Would like to add more fields in the Genral contacts tab Using Outlook 1
D Add-In or Other to Make Outlook More "OneNote Like"? Using Outlook 5
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 2
B Task Filter Not Working When I add too many criteria Using Outlook 0
D Add Tetxbox at form open Outlook VBA and Custom Forms 1
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
B Searching for a Add-In Using Outlook 3
J Add Fillable Fields to Existing Template Outlook VBA and Custom Forms 1
J vb to c# for Outlook add-in. Using Outlook 0
twofivepie GTD Netcentrics add-in for 2016 Outlook VBA and Custom Forms 13
