Script to fetch data from mails in restricted collection and sending them to excel
AJBoink
Hi Could someone review the below given code and help me to sort out the error?
The script is meant to fetch data from mails in a particular date range using pattern matching with regex, and send those data to an excel file. But I have been getting errors while running this script. The script should run against a folder called 'arjun' and then look for mails which matches the required pattern.
Sub mailsInRestrcitedCollectionP1S3()
Dim objNameSpace As Outlook.NameSpace
Dim objSourceFolder As Outlook.Folder
Dim drDate, StartDate, EndDate, StarD, EndD As Date
Dim mailCount As Integer
Dim objVariant, Row, Priority, i As Variant
Dim olItem
Dim itms As Outlook.Items
Dim filteredItms As Outlook.Items
Dim N As Integer
Dim strRestrict, subjct, mailBody, strtTime, resoTime, incTickt, Category, Location As String
Dim ExcelSheet As Object
Dim regexpSubjectCheck, regexpLocation, regexpCategory, regexpdataFromBody As RegExp
Dim M, P, D As MatchCollection
'Dim Category, Location As Object
Dim oMatch, oMatches
Set objOutlook = Application
Set objNameSpace = objOutlook.GetNamespace("MAPI")
Set objSourceFolder = objNameSpace.Folders("Arjun.SL@xe04.ey.com").Folders("Inbox").Folders("arjun")
Set ExcelSheet = CreateObject("Excel.Sheet")
StartDate = InputBox("the date in format m/d/yyyy", "Start Date")
EndDate = InputBox("the date in format m/d/yyyy", "End Date")
StarD = Format(StartDate, "m/d/yyyy")
EndD = Format(EndDate, "m/d/yyyy")
strRestrict = "[ReceivedTime] > '" & StarD & "' AND [ReceivedTime] < '" & EndD + 1 & "' "
Set itms = objSourceFolder.Items
Set filteredItms = itms.Restrict(strRestrict)
Set regexpSubjectCheck = New RegExp
With regexpSubjectCheck
.Pattern = "(\s*FINAL:\s*INCIDENT NOTICE:\s*OneNet\s*\(MPLS\))|(\s*FINAL:\s*INCIDENT NOTICE:\s*US WAN connectivity)|(FINAL:\s*INCIDENT NOTICE:\s*OneNet\s*\(iVPN\))|(\s*FINAL:\s*INCIDENT NOTICE:\s*WAN/MAN\s*Connectivity)|(\s*FINAL:\s*INCIDENT NOTICE:\s*VPN Connectivity)|(\s*FINAL:\s*INCIDENT NOTICE:\s*GWAN\s*II)"
.Global = True
Set regexpLocation = New RegExp
With regexpLocation
.Pattern = ("-\s*\w*\,*\s*\w*")
.Global = True
Set regexpCategory = New RegExp
With regexpCategory
.Pattern = "(\s*OneNet\s*\(MPLS\))|(\s*US WAN connectivity)|(\s*OneNet\s*\(iVPN\))|(\s*WAN/MAN Connectivity)|(\s*VPN Connectivity)|(\s*GWAN\s*II)|(\s*Internet VPN\s*\(I-VPN\))"
.Global = False
Set regexpdataFromBody = New RegExp
With regexpdataFromBody
.Pattern = "(START TIME:\s*\d{2}-\w{3}-\d{4}\s*\d{2}:\d{2}\s*GMT)|(RESOLUTION TIME:\s*\d{2}-\w{3}-\d{4}\s*\d{2}:\d{2}\s*GMT)|(SERVICENOW TICKET: INC\d{7})"
.Global = True
Row = 1
For i = filteredItms.count To 1 Step -1
Set objVariant = filteredItms.item(i)
subjct = objVariant.subject
mailBody = objVariant.Body
If regexpSubjectCheck.Test(subjct) Then
Priority = "P1S3"
Set M = regexpLocation.Execute(subjct)
Location = M(0).Value
Set P = regexpCategory.Execute(subjct)
Category = P(0).Value
Set D = regexpdataFromBody.Execute(mailBody)
strtTime = D(0).Value
resoTime = D(1).Value
incTickt = D(2).Value
ExcelSheet.Application.Cells(Row, 1) = incTickt
ExcelSheet.Application.Cells(Row, 2) = oMatch
ExcelSheet.Application.Cells(Row, 3) = Category
ExcelSheet.Application.Cells(Row, 4) = Priority
ExcelSheet.Application.Cells(Row, 5) = strtTime
ExcelSheet.Application.Cells(Row, 6) = resoTime
If regexpCategory.Test(subjct) Then
Row = Row + 1
ExcelSheet.SaveAs "C:\Script\p1s3.xls"
Set ExcelSheet = Nothing
Diane Poremsky Run a Script Rule: Send a New Message when a Message Arrives New Slipstick.com Articles 2
S using script rule to save attachments on arrival Outlook 2010 Outlook VBA and Custom Forms 9
Davzell Change default pop3 account with script, prf or registery ? Outlook VBA and Custom Forms 0
D Script to parse email and set a task Outlook VBA and Custom Forms 1
L Moving Message Class email via script and Rule Outlook VBA and Custom Forms 3
H Customizing "Send to" Attachment Script Outlook VBA and Custom Forms 5
G Script in rule to send to multiple emails found in message bo Outlook VBA and Custom Forms 11
A Creating archive rule on the clients by script/ Outlook VBA and Custom Forms 3
J VBS Script (macro) for word to open Outlook template. Outlook VBA and Custom Forms 2
