font format discrepancies with Quick Parts
mr_malkovich
Hi there. I'm using Office 365 Business, version 1710. I talk with a ton of people over email every day. To make it easier, I added paragraphs I constantly use into Quick Parts for easy pasting, and I often type in some extra custom stuff to go along with it. Problem is, when some of the recipients of these emails reply, I see my custom text and my Quick Parts texts are in different colors and sometimes even different fonts, making it pretty obvious I've been pasting pre-written text in. The font in my emails and the font in my Quick Parts are identical - Calibri (Body), 11. What gives?
it looks like you are somehow typing in the quoted message part. After inserting the quick part, do you press Enter at the end of the line? If not, try that. It might help to add an enter or two at the end of the QP text - edit one and test it to see if outlook removes the blank line. This will give you more white space between your insertion and the quoted reply.
if all else fails, use format painter to paint your text the same color as the insertion.
P default font when sending email from browser Using Outlook 1
e_a_g_l_e_p_i Adjusting font size in folders Using Outlook 1
S Customize the autocolor font choices for replying/forwarding messages Outlook VBA and Custom Forms 2
M Message list font changed after update Using Outlook 2
P Message List Font Changed Using Outlook 6
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
R Setting font and color used when replying to an email Outlook VBA and Custom Forms 3
D font control by keyboard Using Outlook 2
Steven 2007 New PC vs Old PC - Micro Font on Inbound Emails :( Using Outlook 4
D Font in Reply is much larger than normal, how to reset ...? Using Outlook 4
Rupert Dragwater Can't change font size Using Outlook 5
O How to paste website content using a specific font and removing URLs Using Outlook 2
T "From" field font size in table list of emails Using Outlook 0
S Default Font in body of Task Using Outlook 0
Diane Poremsky How to Change the Font used for Outlook's RSS Feeds Using Outlook 0
J Increase font size of message body Using Outlook 5
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
J Font size changed in new mail messages Using Outlook 5
Rupert Dragwater unable to change font sizes in some replies Using Outlook 3
D Conditional formatting - font sizes Using Outlook 3
O How to increase Font size in Outlook 2013 Using Outlook 1
Fozzie Bear Change the colour or font of individual email accounts in outlook 2010/13 Using Outlook 1
K Untitled Appointment Font Using Outlook 1
J Change Default View - Color and font Using Outlook 3
J Changing Contact Notes Font Outlook VBA and Custom Forms 9
R Can't modify Outlook view font with IE anymore (even though IE still affects print font) Using Outlook 5
B Outlook 2007 Save Current View,Font,Toolbar Settings Using Outlook 6
O Copy email content and paste into new Word Document using a different font Using Outlook 1
P Outlook 2010 custom form olk control font size increases everytime form is published Outlook VBA and Custom Forms 1
M Default font Using Outlook 2
L Font Type and Space Using Outlook 7
D Default Font in Outlook 2013 Using Outlook 3
F Outlook 2010 custom font style duplicates itself every time I save a task Using Outlook 0
D Point Size for Fonts in Custom Font Style (Outlook 2013) Using Outlook 0
