Capturing Send Variables without using Application_ItemSend in ThisOutlookSession
Outlook 2016 64 bit
I want to place a custom button in the send window's ribbon which allows me to capture the sender, recipient, subject, body and date/time sent and pass these through to an Access database then send the email as normal.
I have found out how to get these variables using the Application_ItemSend event in ThisOutlookSession. However, I don't want it to happen each time, only when the user selects the Custom button instead of the standard Sent button.
Here's the code I've been using in ThisOutlookSession which has been getting the variables I need:
Dim recip As Outlook.Recipient
Dim pa As Outlook.PropertyAccessor
Dim thisMail As Outlook.MailItem
Dim senderEmail As Variant
Const PR_SMTP_ADDRESS     As String = "http://schemas.microsoft.com/mapi/proptag/0x39FE001E"
With Item
Debug.Print .subject
Debug.Print .body
Debug.Print .senderEmailAddress
Debug.Print "Sent On: " & Now()
Set recips = .recipients
For Each recip In recips
Set pa = recip.PropertyAccessor
Debug.Print pa.GetProperty(PR_SMTP_ADDRESS) 'recip.Name & " " &
Thanks in advance!
There are a couple of ways to do it, but they all use the same basic idea - an If statement...
If you want users to say 'send to access' before sending, use two macros - one to set a value that says 'yes' and add an if statement to the itemsend - if the variable = yes then send to access. The other way is to bring up a dialog each time asking. The if statement sends to access if yes, skips it if no.
Example from How to set a flag to follow up using VBA
prompt$ = "Do you want to flag this message for followup?"
If MsgBox(prompt$, vbYesNo + vbQuestion + vbMsgBoxSetForeground, "Add flag?") = vbYes Then
' do flag
end if
Outlook 2016 64 bit
Hi Diane, thanks for your reply.
When I paste this code into a module I get a compile error on WithEvents saying Only Valid in Object Module. Which parts go in which type of module?
Option Explicit
Dim SetFlag
Private WithEvents olSentItems As Items
Dim objNS As NameSpace
Set objNS = Application.Session
' instantiate objects declared WithEvents
Set olSentItems = objNS.GetDefaultFolder(olFolderSentMail).Items
Set objNS = Nothing
Private Sub olSentItems_ItemAdd(ByVal Item As Object)
Dim prompt As String
If SetFlag = vbYes Then
With Item
.MarkAsTask olMarkThisWeek
' sets a due date in 3 days
.TaskDueDate = Now + 3
.ReminderSet = True
.ReminderTime = Now + 2
.Save
SetFlag = vbNo
Sub SayYes()
SetFlag = vbYes
did you paste it into thisoutlooksession or a new module? Those macro only work in thisoutlooksession (because they are automatic) - the error is telling you withevents only works in thisoutlooksession.
Outlook 2016 64 bit
I've put this code into thisOutlookSession and assigned 'Say Yes' to a custom button on the ribbon. I click that button, then click the Send button, but it's not firing the code. Any suggestions?
Option Explicit
Dim SetFlag
Set objNS = Nothing
Dim recips As Outlook.recipients
    With Item
    Debug.Print .body
    Debug.Print "SentOn: " & Now()
SetFlag = vbNo
Sub SayYes()
SetFlag = vbYes
    Set objApp = Application
        Case "Explorer"
        Case "Inspector"
    Set objApp = Nothing
End Function
if you are using a button, set a value -
Sub SayYes()
SetFlag = "Yes"
then use
If SetFlag = "Yes" Then
clear it using
SetFlag = ""
Outlook 2016 64 bit
Hi Diane, yes I've got an IF block in there, unfortunately the Private Sub olSentItems_ItemAdd(ByVal Item As Object) isn't being fired after I've sent an email. Perhaps I've got it set up wrong?
Either restart outlook or click on the application_startup macro and click Run.
J Capturing forward event when multiple items are selected Using Outlook 0
D Capturing Data from a form into excel Outlook VBA and Custom Forms 1
B Capturing form data Outlook VBA and Custom Forms 1
S Re: Capturing Outlook Forms Events Outlook VBA and Custom Forms 1
D Capturing Outlook Forms Events Outlook VBA and Custom Forms 21
F Send As a Gmail account via outlook Web Using Outlook 3
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
M Can't send email in outlook.com Using Outlook 9
R Can't Send calendar share invite Using Outlook 5
R Can't send messages to groups in Outlook Using Outlook 2
J Updating existing entry on shared calendar wants to send update from delegate Using Outlook 0
soadfan Outlook won't send e-mail when offline Outlook VBA and Custom Forms 19
K Delay Send and Mail Merge Outlook VBA and Custom Forms 4
L How to automaticlly Send/Receive every 3 mins but override send if send/receive is pressed Using Outlook 2
D Delay Send not working Using Outlook 3
F Send multiple batch tasks to single person Using Outlook 3
R Prompt asking the user to send email to folder as *.msg file Outlook VBA and Custom Forms 1
D Default Send Account that Works? Using Outlook 0
D Outlook.com in Outlook 2016 Trys & Fails to Send on Behalf of Itself Using Outlook.com accounts in Outlook 2
