unexpected problem in outlook
DruinaBiscardi
Outlook 2013 64 bit
I am quite often using MS Outlook 2013, but unfortunately, since today I've not been able to see mine messages in .pst file. Yesterday all was simply fine.
bjornfeulner
Outlook 2016 64 bit
I found out this one method from search machine, take a look...
When replacing a .pst file. Make a Copy of the File you are going to use and use the Copy. Then, if anything goes wrong you still have the original file.
I am no expert ~ so wait until someone tells us whether this is right or not.
Delete the corrupted .pst file and then import the new .pst file
One of my friends also advise to repair large PST file via following sources
http://smallbusiness.chron.com/repair-microsoft-outlook-pst-file-79963.html
https://www.msoutlook.info/question/329
W Outlook 2019, Outlook Proplus v1808/1809 Unexpected Calendar Cache Using Outlook 4
Diane Poremsky Don’t be fooled by unexpected attachments! New Slipstick.com Articles 0
T Unexpected change of the order of the folders in my navigation pane Using Outlook 6
L Re: An Unexpected Error Has Occurred Using Outlook 2
S Distribution list failure - "an unexpected error has occurred" Using Outlook 7
