VBA Macro - Run-time error '424': object required - Help Please
Steve Tomalin
Outlook.com (as MS Exchange)
I'm afraid I'm no developer, but I'm trying to cobble together a small automation solution in Outlook for myself, using some example code I found on the web (which originated from Sue Mosher), but I'm afraid I've stumbled at the very first hurdle.
I want to get Outlook to 'do something' within the current, open email form, each time I create a new email, or perform Reply, or Reply All, or Forward on an existing email. At this point, I don't think the 'something' is important, I'm hitting my problem before even getting that far! Here is my code, as it stands:
Dim WithEvents colInsp As Outlook.Inspectors
Set colInsp = Application.Inspectors
Private Sub colInsp_NewInspector(ByVal Inspector As Inspector)
If Inspector.CurrentItem.Class = olMail Then
Set objMail = Inspector.CurrentItem.Class
If objMail.Sent = False Then
MsgBox "Hello World", vbOKOnly, "Debug Message"
Set objMail = Nothing
I replaced an original line from the example code with the line:
I did this on the expectation that when I clicked New Email, or Reply etc., the email form would open and I'd then see the message box, just to prove to myself that the macro would execute as I was hoping/expected.
The macro certainly seems to begin to execute when I create a new email or begin a reply, but it fails at the line:
The error message is:
It would seem that the eror is occurring before the line I replaced, so I'm thinking that my line is not the problem here. I'm using Outlook 2016, so I wonder if there might be a compatibility issue with the code, which probably predates this version? If that's not it, then I'm wondering if maybe I've simply not created the macro within Outlook in the correct way, or in the correct location, or with the correct properties, or something like that?
If anyone could provide me with some assistance here, I'd be very grateful. I think that once I have the basic functionality working, I'm hoping I will be able to create the rest of the macro (which will do the thing I want it to do) without needing any further assistance. Many thanks, in advance.
Kind regards,
Steve
Steve Tomalin
Brilliant, it works! Makes me wonder why that '.Class' was in the original example, but I guess it could just have been a typo.
Anyway, many thanks indeed for your help, I can now get on with trying to acheive the primary objective!
Kind regards,
Steve
Year, most likely a typo or they copied it from the line above and forgot to remove it - i've done that before. :(
M Run external program from Outlook VBA macro Outlook VBA and Custom Forms 5
J Macro only runs within VBA Editor Outlook VBA and Custom Forms 2
D VBA macro printing attachments in shared mailbox Outlook VBA and Custom Forms 1
S Outlook 7 VBA macro for multiple filing Outlook VBA and Custom Forms 1
Philip Rose Recreating a WORD Editing Macro to use in Outlook VBA Outlook VBA and Custom Forms 4
M recover deleted items vba macro Outlook VBA and Custom Forms 2
S VBA Macro to VBScript Outlook VBA and Custom Forms 1
B Outlook vba macro Using Outlook 1
B Auto BCC VBA macro: how to add exceptions? Using Outlook 28
D VBA Macro Works in 2007 but errors in 2010 Using Outlook 2
N VBA Procedure (or Macro) to Stop Outlook from Closing? Outlook VBA and Custom Forms 2
D New Macro / VBA Outlook VBA and Custom Forms 7
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
S macro ist just worling wenn vba editor is open! Outlook VBA and Custom Forms 1
S Excel vba code to manage outlook web app Using Outlook 8
