Macro using .SendUsingAccount only works the first time, after starting Outlook
Steve Tomalin
Outlook.com (as MS Exchange)
Hi All,
I've put a macro together from examples I found on the web, which uses the Inspectors.NewInspector event to run code when a new item window opens, whether New, Reply, ReplyAll or Forward. Amongst other things, the macro conditionally changes the value in the 'From' drop-down list, using the MailItem.SendUsingAccount property.
The problem I have is that the setting the SendUsingAccount property seems to work when the macro runs for the very first time, after starting Outlook, but in all subsequent runs of the macro the MailItem.SendUsingAccount line fails to set the value. The MsgBox I included for test purposes appears every time, so I know the macro runs on each occasion.
Could anyone show me what needs to be done with this macro to get it working every time please? Below is a cut down version of the macro, to keep things simple.
Kind regards,
Steve
Dim WithEvents colInsp As Outlook.Inspectors
Set colInsp = Application.Inspectors
Private Sub colInsp_NewInspector(ByVal Inspector As Inspector)
Dim OutApp As Outlook.Application
Set OutApp = Application
If Inspector.CurrentItem.Class = olMail Then
Set objMail = Inspector.CurrentItem
If objMail.Sent = False Then
With objMail
MsgBox "Setting SendAccount Next"
objMail.SendUsingAccount = OutApp.Session.Accounts.Item(5)
Set objMail = Nothing
i don't know why your code doesn't work, but this is working here with pop accounts (if i hit reply to opened messages, but not in reading pane). i put your code together with Use a Default Subject for New Messages - which is based on Michael's NewInspector and Inspector_Activate - VBOffice
Private WithEvents m_Inspectors As Outlook.Inspectors
Private WithEvents m_Inspector As Outlook.Inspector
  Set m_Inspectors = Application.Inspectors
Private Sub m_Inspectors_NewInspector(ByVal Inspector As Outlook.Inspector)
  Set m_Inspector = Inspector
Private Sub m_Inspector_Activate()
If TypeName(m_Inspector.CurrentItem) = "MailItem" And _
m_Inspector.CurrentItem.Sent = False Then
Set objMail = m_Inspector.CurrentItem
    objMail.SendUsingAccount = OutApp.Session.Accounts.Item(2)
  Set m_Inspector = Nothing
Actually, Michael explains why on his site - there are things you cant change in new inspector but can change in inspector_activate.
Steve Tomalin
Many thanks Diane, I'm very grateful to you!
I'll play around with the macro you've provided above and see if I can get it working on my machine. As long as it does, I'm fairly confident I can move the rest of my macro code into it and I should then have the finished, working article!
Will keep you posted. Thanks again.
Kind regards,
Steve
Steve Tomalin
Hi again Diane,
Having dropped your example macro into my Outlook environment, I'm pleased to confirm that it appears to be working great with my IMAP Outlook.com accounts and for successive new emails, replies, reply-alls and forwards!
Once I've got my end result working as intended, I'll post it back here with an explanation as to what does and why I needed it. You never know, it might come in handy for a few other people who may have bumped into a similar situation or set of requirements as me and, based on the fact that the majority of it has been plagerised from other people's stuff and help from you, I feel it should be openly available by default!
Kind regards,
Steve
H send reminder if no reply received on first or original email using macro Using Outlook 2
Diane Poremsky Embed Images in New Messages using a Macro New Slipstick.com Articles 0
O using macro to send attachments Using Outlook 3
T Using a macro to send email to diffrent address Outlook VBA and Custom Forms 1
S Editing an email with notes and saving it for record using Macro Outlook VBA and Custom Forms 3
reza Macro to automatic reply using orignal mail Outlook VBA and Custom Forms 10
nathandavies How to save emails to a specific folder on a network automatically using a macro Outlook VBA and Custom Forms 14
B Auto reply using macro include original email Using Outlook 4
J Macro generating email using default signature and hyperlink Outlook VBA and Custom Forms 5
M Reply Macro using O365 Connected Account Using Outlook 2
H using macro for sending multiple mail in outlook Outlook VBA and Custom Forms 1
J Specify Font Name or Face using VBA Macro in Word Outlook VBA and Custom Forms 2
R Trigger Application_ItemSend event when sending using Access macro Outlook VBA and Custom Forms 2
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 2
