other user's mailbox won't open, forms disappeared
mr_malkovich
Outlook 2007
Hi all. Using Office 365/2016 on Windows 10. I'm in the early stages of phone support hell with GoDaddy on this issue, and I have a sneaking feeling they're gonna do what they always do when Outlook questions get too complicated: tell me I have to call Microsoft, who in turn tells me I have to call GoDaddy since they're my vendor, et al. In anticipation of that loop-de-loop of suicide, I figured I'd post the query to the one place on Planet Earth that might have a clue.
I have two colleagues with mailboxes on my 365 account. For months their mailboxes have been easily accessible through the left vertical pane on my main Outlook screen. I click on their names and can view and edit their inbox, sent items, you name it. Two days ago one of those mailboxes disappeared from that vertical pane. I noticed that mailbox had also disappeared from Permissions so I reinstated it, set it to Owner, and got the mailbox name back in that pane, but when I access it, I get the attached prompt.
I've also noticed that I can no longer access my Personal Forms screen. For instance, I'm trying to add/remove custom columns on my Contacts views like I always do, but when I choose 'forms' I only get a choice of Enterprise forms, not my personal ones. So something's up.
Anyone got any ideas here?
The dialog is saying the something is using the ost file - it's not an uncommon error message, especially if you use skype for business (which accesses it for communication history). Skype is 100% of the cause of that message here, but any application that accesses outlook data could trigger it too.
I'm wondering if the profile is corrupt. Do you have a second computer you can create your profile on to test ? If it works, then this profile is the problem. (A second windows account will also work for testing.)
BTW, this has me concerned, especially if you logged in and set the permissions in the admin center. They should never disappear on their own - only the mailbox owner or someone with admin permission can change it.
FWIW, you could probably get a better deal (less money, larger mailbox) and more control over the tenant if you get office 365 directly from microsoft. Migrating isn't difficult, but because the domain is already in office 365, you need to migrate at a slow time as you need to remove the domain from the office 365 account before moving to a tenant direct from microsoft. Some mail could bounce during the short period of time the address is not hosted anywhere.
Godaddy has good 'first year' rates and i thought the support was good when i tested their offering (and compared it to getting it directly from MS), but the mailbox quota was somewhat smaller (my plan had 5 GB, MS gave 50GB) and some things in the admin center were not accessible. (Plus you were limited to one domain.)
mr_malkovich
Outlook 2007
And heaven knows I'd like to hear the last of GoDaddy's support team sending me back into that GoDaddy/Microsoft support ping-pong. But the mere thought of migrating right now is laboring my breathing. Maybe once my life calms down a bit (hi from India).
Yes, I've had Skype for Business running recently. Skype For Business is supposed to be Outlook365's communicatino tool but it causes this kind of conflict? That's just perfect, really. I changed my settings so that it doesn't open on startup, and restarted the laptop, but the mailbox problem persists (note, only with one mailbox. my other colleague's mailbox is fine). Another program that has recently been attempting to start at startup alongside Skype for Business is OneDrive for Business. I always hit cancel. I have OneDrive running on my computer at all times, but I'm assuming it's not the Business version? Could OneDrive be screwing around with things too?
mr_malkovich
Outlook 2007
OST is in use and cannot be accessed - Master & CmdR
Seems like the problem in question. So how do I uninstall Skype for Business and OneDrive for Business? Because they are not in my Remove Programs pane. And do I really have to uninstall Skype for Business? It's actually kind of useful at times, especially when working with my remote employees.
You're in India? I would have guessed UK, only because of the middle of my night posts. :)
Onedrive won't be affecting it. Skype for business saves conversations to the mailbox - it need to access the mailbox, which can cause the error. I turned off that feature and don't have a problem. (I also don't use skype for biz a whole lot, so maybe it hasn't helped as much as i thought it did.)
Exit Skype (in Task manager) and restart outlook. Does it work?
You don't. The best you can do is disable them, but then you can't use them...
The information in that link is somewhat misleading and would only apply if you had separate installs. Skype and OneDrive are included in the office 2016 install (they were not in some office 2013 installs).
How large is the ost? I hate to suggest this is the ost is close to or over about 10 GB or if you have a slow connection, but a new ost could fix the problem. Close Outlook. Go to %localappdata%\microsoft\outlook and rename the ost file. Restart outlook and let it sync.
I have two articles on the the problem - this one suggests exiting skype to test it then checking the exe properties.
How to Prevent Skype (Lync) from Locking Outlook's .OST File
This one blames a sharepoint calendar synced to outlook. The error message isn't quite right though.
"Failed to open message store" Error
mr_malkovich
Outlook 2007
I'm from LA. But I travel pretty much nonstop....
Quick thought. Could Skype for Business being active on the machine of my colleague with the screwy inbox be an issue?
mr_malkovich
Outlook 2007
Update! I turned off "save conversations" in Skype for Business (and deleted the Conversation History in Outlook for good measure), restarted comp, and the mailbox is accessible again. Thank you as always.
It could. I would force skype closed then restart outlook - if the problem goes away, it was skype and I would start with a new ost file and try different settings in skype options.
These are the settings I'm currently using - they seem to help. I'm not sure when conversation history was enabled - probably after an update to see if the problem was fixed - but disabling most of the integration seemed to help.
Like i said, i don't use skype a lot - a few of my clients are heavy users and use it to contact me and i use it for up to 2 or 3 meetings a month with microsoft - and that could be why the error hasn't come back in a while.
mr_malkovich
Outlook 2007
It returned! Everything was great for like three days. And now it's back.
You think I should start a new OST? Do you have a good link for a step-by-step? And isn't that like inviting a million more problems? or no?
I'm not sure a new ost will help... if you want to try, right click on the account name in the navigation pane, choose open file location. This opens File Explorer with the ost file for that account selected. Close outlook, rename the old ost and restart outlook.
mr_malkovich
Outlook 2007
I don't see Open File Location when I right-click, but I see Data File Properties, which when chosen prompts 'cannot display folder properties'. Also worth noting: I can't access my Personal Forms when this problem occurs. Something is jamming Exchange up.
mr_malkovich
Outlook 2007
Other things to note:
On Office365 via browser I realized the mailbox in question - judy@mydomain.com - wasn't in my list of folders like my other colleague's is - christy@mydomain.com. I went through the steps to add it, and it's now sitting nicely in the web version, completely accessible.
Now that I think about it, that's something else to note - christy@mydomain.com has zero problems. It's been hooked up for years. judy, not so much.
Also, I noticed an nst file. Tried deleting it and it just pops back up. I read that it's for Lotus Notes? Outlook Hotmail connector? What is Lotus Notes? I don't use anything like that.
Finally, I'm noticing that whenever I shut down outlook a new inferences.xml file appears in the root Outlook16 folder.
mr_malkovich
Outlook 2007
Read somewhere to look out for ucmapi.exe in the task manager because apparently that's Skype for Business and lo and behold.. it's running, even after I set SFB to NOT automatically turn on when I log onto Windows. I restarted the computer and SFB STILL opened up. And there seems to be a couple other related programs hanging around. As we speak the problem mailbox is currently accessible from Outlook proper, but who knows how long it will last. How is it remotely acceptable that Office365's flagship messenger conflicts with Outlooks's root file? How can this be? How?
Update: restarted the computer and the mailbox is gone again.
Right click on the account name - open location is near the top.
personal forms is stored in the mailbox, i think (will need to see if they sync to my new computer), so it makes sense they go away when this error comes up.
mr_malkovich
Outlook 2007
Open File Location is actually greyed out for the problem mailbox!
Now, my OTHER colleague's mailbox - christy@mydomain.com - when I right-click on that one, Open File Location is available, but when I choose it I get the message The Attempted Operation Failed. An Object Could Not Be Found.
They used the extension in the past for notes (and Exchange competitor) and for an early version of the Hotmail Connector and decided to reuse it for the new groups feature rather than making a new extension. You should have one for each account (in the file, account settings list) on office 365.
its only available for actual accounts in your profile, not shared mailboxes, and only for cached exchange (which is the default), not online exchange. (Also available for IMAP and pop/pst.)
mr_malkovich
Outlook 2007
Is it easier if I set these mailboxes as cached exchange? Anything to end this. The judy mailbox was accessible for 9 minutes. It was beautiful. But it's over now.
It's used with exchange accounts to keep track of something, but i forgot what for. :(
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
I shared mailbox - can i create a rule (vba) for every user? Outlook VBA and Custom Forms 1
T Messages no longer move to quote folder on shared mailbox after user adds -D to folder name Outlook VBA and Custom Forms 1
J Cannot copy outlook form to mailbox of exchange 2k13 user Exchange Server Administration 1
M Is there a Step-by-Step how-to Disable and Attach a Mailbox to a Different User for Exhange 2010? Exchange Server Administration 4
B Re: Exchange OOF / EWS Problem - The user and the mailbox are in different Active Directory sites Exchange Server Administration 0
T The ACL for object "<exchange mailbox user>" is not in canonical order Exchange Server Administration 4
J Receive mail successfully but failed to deliver into user mailbox - Exchange 2007 Exchange Server Administration 6
P Setting permission on user Standard when mailbox is created Exchange Server Administration 1
R Error attempting to create a mailbox for a new user Exchange Server Administration 4
M Mails get deleted accessing a user mailbox with a different user Using Outlook 2
M i can't Disable Junk E-Mail filtering on a specific user mailbox Exchange Server Administration 1
X What happens to the mailbox when you delete a user from AD Exchange Server Administration 3
S Single User Mailbox not shrinking Exchange Server Administration 8
S Restore Mailbox items to another user's mailbox Exchange Server Administration 2
C Outlook 2010: How do I cache only user's mailbox, not all mailboxes Using Outlook 4
G Convert Linked mailbox to User mailbox - (Disable-mailbox -identity) Exchange Server Administration 2
P Remove mailbox when DC doesn't have an associated user Exchange Server Administration 2
T Not getting Mailbox Warning messages that tell a user there mailbox is getting to full Exchange Server Administration 5
J creating user account from mailbox wizard context Exchange Server Administration 3
J Deleted a user from AD by mistake. Can I get his mailbox back??? Exchange Server Administration 10
G Open another user's Inbox/Mailbox via PowerShell (Outlook 2010 & Exchange 2010 SP1) Exchange Server Administration 6
T Possible to define Mailbox User alias? Exchange Server Administration 4
T Move a mailbox to a different user Exchange Server Administration 8
N How to centrally identify permissions granted to user mailbox. Using Outlook 1
M User with 9Gig mailbox wants more space Exchange Server Administration 10
I How To Create/Generate an Archive of A User Mailbox in Exchange 2010 Exchange Server Administration 2
A Want to delete mailbox on 2010 but want to keep User Account in AD Exchange Server Administration 6
W OWA, ActiveSync and Outlook Anywhere for a linked mailbox user Exchange Server Administration 1
T Existing AD user does not show in Exchange 2010 exsiting users list for new mailbox Exchange Server Administration 5
S Exchange 2010 added to 2007 Organization. New 2007 Mailbox user not shown in Global Address List Exchange Server Administration 1
S add other/external email address to a user account/mailbox Exchange Server Administration 17
M Error Outlook Web Access is not currently available for the user mailbox that you are trying to acce Using Outlook 14
G New user profile in OS and mailbox on Exchange2010 - Outlook 2007 hangs Exchange Server Administration 8
D Migration user logs on ews and creates mailbox with english foldernames Using Outlook 1
S Exchange OOF / EWS Problem - The user and the mailbox are in different Active Directory sites Exchange Server Administration 16
S outlook 2007 ask user to login mailbox on exchange 2010 Exchange Server Administration 3
M How do I retrive User permissions for a Mailbox? Outlook VBA and Custom Forms 4
icacream Enter your user name and password for the following server. Using Outlook 5
R Creating a user defined function Outlook VBA and Custom Forms 3
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
G <mailto:user@domain.com<mailto:user@domain.com<mailto:user@domain.com>>> Using Outlook 4
F MAPI, User Defined Fields and perspective after 20 years Outlook VBA and Custom Forms 0
