Need help syncing contacts to iPhone X
nudookj
Outlook 2013 64 bit
I currently hold two smartphones: Samsung Galaxy S5 and iPhone X. What is the right steps to sync Outlook contacts from Samsung to my iPhone X?
You won't sync phone <==> phone <==> desktop, you'll sync devices <==> server <==> desktop -so you need something to sync to the server.
The easiest is using an outlook.com account (or Office 365 or Exchange).
Does the android sync icloud calendar and contacts? (I will need to charge my android and check) if so, you could sync to icloud, using the icloud addin in outlook. That could be the second best and free - but the icloud is a separate data file in Outlook, which many people don't like.
Another option is using companionlink or gsyncit to sync outlook desktop contacts to gmail and let the devices sync with the gmail account. This will keep everything in the default data file, just like it is not. Its not free though.
nudookj
Outlook 2013 64 bit
I didn't find a way to sync iCloud account on Android. Thanks
Personally, i think using a sync utility and syncing to gmail would be better, unless you have an outlook.com (or exchange) account.
Naskerz
I think so too . I don't know much about it, but third-party tools are good for people who don't have any experience. user just need to connect your phone to computer and transfer data
Gakkerty
Exchange Server 2013
Here are the following steps that I used to transfer my contacts from my Galaxy S6 to my iPhone 7 :
1. Go to contact and export your address book to the android device
2. Connect your phone to your computer and copy the .vcf file on it
3. Create a new e-mail and send the e-mail to the address that it is configured on your iPhone device
4. Attach the .vcf file and send the e-mail
5. Go to your iPhone and look for that e-mail
6. Once you found it, open the attachment and upload the contact to your address book
That is all.
Gakkerty
That is all.
if you still not understand what to do, maybe this article helps.
AT&T Mobile Transfer App - Transfer Phone Contacts & More
if you find other tools, don't forgot to share with us.
Parteuj
If you have synced your contacts from Samsung phone to Google, you can add and login your google account on your iphone X, or you can move your contacts via "Move to iOS" app.
Yankker
It is possible to use Google /Gmail / iTunes /iCloud , if there are a lot of contacts that you want to transfer ,I would not recommend using them, as some data might be lost.
G Need help configuring a PRF for Outlook 2010 and 2013 Using Outlook 0
K Excel Import Option: Need Help Updating Existing Records BCM (Business Contact Manager) 0
K Need help concerning emails linking to BCM. BCM (Business Contact Manager) 0
J Need help with installation of BCM in Outlook2013 BCM (Business Contact Manager) 5
F Outlook 2010 - Need help with a custom field. Using Outlook 3
L Need help getting calendar/contacts/tasks/notes back! Using Outlook 3
P Need help/Gmail accounts show separately/Outlook 2013 Using Outlook 0
J Need Help Extracting Email Content into Excel Specifically the Attachment Name Using Outlook 3
A Need Help with BCM2010 Sharing on outlook 2013 Scenario! BCM (Business Contact Manager) 1
W I Need help with vb.net and outlook 2010 Using Outlook 2
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Need help with combo boxes in messages! Using Outlook 10
D Need help understanding which pst-file to use! Using Outlook 0
U Need a help please Outlook 2007 crashing Using Outlook 2
Z Need Help Outlook 2007 inbox and address book view Using Outlook 2
B Need help adding a background color to the compact list items in Month view. Calendar Printing Assistant 1
B Need help adding an image next to the Month Name in the header. Calendar Printing Assistant 1
B Ok - a complicated one - but really need help (auto formatting) Using Outlook 9
B OUTLOOK 2000, Need Help ! Outlook Wishlist 1
P To Use BCM or not...I need help BCM (Business Contact Manager) 1
T Need help making RULE to prepend email SUBJECT Using Outlook 3
V Need help on configuring Outook 2003 Rules and Alerts... Using Outlook 2
X business owner in dire need of help outlook is not syncin my contacts! Using Outlook.com accounts in Outlook 2
D Need email verification for international emails, help? BCM (Business Contact Manager) 2
S MAcro - Need help in getting the recipients in to filed / cc field toput in an array Outlook VBA and Custom Forms 4
K Need help Publishing a new Task form! Outlook VBA and Custom Forms 1
A Need help in creating a mass emailing plugin Outlook VBA and Custom Forms 1
T need help w/ sending an e-mail -- outlook 2007 addin Outlook VBA and Custom Forms 2
A Wishlist Arthur workman I need the community's assistance thank you Using Outlook 3
A from Arthur to anyone I need your expertise assistance Using Outlook.com accounts in Outlook 7
