Outlook Forms Help
Nick Anderson
I am creating a Custom Outlook form. I am using the olkDateControl option from the Control Toolbox. When I set this up and run the form I can enter a date just fine, but when I go to view the email, the date field shows none as an option verses the date that I entered in.
What do I need to do to correct this? I am doing separate layouts, one for the compose page and one for the read page.
Similar situation with the olkTimeControl option as well.
Nick Anderson
Diane, for some reason I missed this reply. Yes, I am setting these to custom fields, but I am only using one view and not separate views for the data. The None text is not critical but just more of something I was checking to see if we could get rid of.
J Outlook 2010 Forms Help Needed "A field in this form requires a value." Using Outlook 6
L Help using forms in Outlook Outlook VBA and Custom Forms 2
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
V Outlook Forms: Formatting a Label with 2 different styles Outlook VBA and Custom Forms 1
B Outlook Custom forms Using Outlook 0
N Export Outlook custom forms fields to excel Outlook VBA and Custom Forms 1
Diane Poremsky How to clean up Outlook's Forms Cache New Slipstick.com Articles 0
Diane Poremsky Designing Custom Outlook Forms New Slipstick.com Articles 0
G Outlook forms text input Outlook VBA and Custom Forms 1
J Outlook 2013 Forms Issue Using Outlook 1
N Outlook Forms Not Displaying Outlook VBA and Custom Forms 6
D Using Follup in Custom Forms Outlook 2013 Using Outlook 9
K Outlook Crash on referencing forms Using Outlook 1
M does outlook 2013/365 on mac support custom forms? Outlook VBA and Custom Forms 1
R Viewing & Using custom forms/tasks in Outlook 2013 Using Outlook 1
W Outlook 2010 Forms Using Outlook 1
G Questions on creating Outlook forms Using Outlook 0
O Outlook 2013 and Organizational Forms Library Using Outlook 2
M Outlook 2010 Forms Using Outlook 1
M Add custom locations to Outlook Forms "Look In:" drop-down list Using Outlook 5
J Update Outllook 2010 to Outlook 2013 - Incorrect Forms Using Outlook 2
M Workarounds for sharing custom Outlook 2007 forms? Using Outlook 3
J Outlook Forms 2010 Sent form will not open Using Outlook 1
P Outlook Forms??? Using Outlook 1
P Unable to delete custom forms in outlook 2010 Using Outlook 1
O Outlook custom forms (2003) Using Outlook 5
G Outlook Forms Blank once sent. Using Outlook 1
A Outlook 2013 corrupting custom forms? Using Outlook 34
T Outlook 2007 forms: Check boxes and free text boxes not retaining data Using Outlook 1
N Creating dynamic forms in outlook?? Using Outlook 2
G Outlook 2007 Forms Compatibility Issues Using Outlook 0
C Outlook Forms: Validation Using Outlook 7
J Outlook 2010 Editing Forms Using Outlook 3
S Outlook 2010: Cannot save forms templates to folder list Using Outlook 4
F can I use Outlook 2007 to create peer review/approve/reject forms Outlook VBA and Custom Forms 1
H Exporting Outlook Forms to Access or Excel Outlook VBA and Custom Forms 2
B Re: Outlook Forms E-mail Creation Sending Blank Fields Outlook VBA and Custom Forms 1
L Outlook 2003 Forms Outlook VBA and Custom Forms 1
F Outlook Calendar forms Outlook VBA and Custom Forms 2
B strange change in Outlook 2000 forms Outlook VBA and Custom Forms 1
J Customizing fields in Outlook forms Outlook VBA and Custom Forms 1
I Today function in Outlook Forms Outlook VBA and Custom Forms 1
A Outlook Forms Outlook VBA and Custom Forms 1
A Outlook 2007 forms Outlook VBA and Custom Forms 1
B Are their other Outlook Journal entry forms besides the standard? Outlook VBA and Custom Forms 1
S Re: Capturing Outlook Forms Events Outlook VBA and Custom Forms 1
D Capturing Outlook Forms Events Outlook VBA and Custom Forms 21
M Public Folder Forms Question. (Outlook v.all - Exchange 07) Outlook VBA and Custom Forms 1
