Outlook 2016 search problem persists after applying all known solutions
Wade Campbell
Outlook 2016 64 bit
Windows 10 Home, version 1709, OS build 16299.192
Outlook 2016, version 1711, Build 8730.2175
PROBLEM: search in email folders does not work (“No results.”) Search in iCloud-based Contacts and Calendar works, but search in PC-based Contacts and Calendar does not work.
Ran in Safe Mode -- SEARCH WORKS
Ran scanpst.exe on pst file multiple times – result was always the following… i.e., scanpst does not seem to fix the problems.
“Only minor inconsistencies were found in this file. Repairing the file is optional.”
Running in normal mode (i.e., not Safe Mode) with disabled macros and disabled add-ins, after SFC /SCANNOW, after rebuilding Outlook indices, after running Stellar Phoenix Outlook PST Repair software -- SEARCH DOES NOT WORK ("No results")
Any suggestions???
Do you have anything in the calendar and contacts folders? iCloud sucks them into the icloud folders in outlook.
Wade Campbell
Outlook 2016 64 bit
In Outlook Calendars, I have two groups: "My Calendars" and "iCloud". There is nothing in the calendars under "My Calendars". Does search not work on the calendars under the "iCloud" grouping? The situation is similar for Contacts, i.e., two groups, with all contacts in the iCloud file. Again, shouldn't I be able to use Outlook to serach on these "iCloud-based" databases?
it should work - i'm guessing this is an extension of the search bug. will test it here to confirm.
Yeah, it worked ok here.
Was the update to 1712 installed since Jan 31? That fixes most of the problems with the early Jan update.
Wade Campbell
Outlook 2016 64 bit
I just upgraded to version 1801, but still cannot search things in OL.
Don't know if this could be the issue ---- on my previous laptop (Outlook 2010), I used "CodeTwo Sync for Outlook" to sync Outlook and iCloud -- worked fine. When I got a new laptop recently (Outlook 2016), I had the impression that Outlook and/or iCloud had been enhanced so that I no longer needed CodeTwo -- syncing works fine, but no search.
I have two email accounts -- one is my personal email (wade@wandkcampbell.com) and the other is the iCloud account (...@icloud.com) that I believe I needed to set up in order to be able to sync my iPhone with my Outlook -- both are IMAP/SMTP.
you don't need icloud email if you don't actually use it - icloud set up adds it automatically but you an delete it if you don't need it. I don't think it is causing problems, but who knows. :)
I didn't test searching for appointments in icloud, only email - is search failing in email or just in the calendar? (and probably contacts)
btw, click in the search field then go to search tools, locations to search - is the icloud checked?
W Search Incomplete Outlook 2016 Using Outlook 5
E Outlook 2016 Inbox search bug Using Outlook 1
Randy Redekopp Outlook 2016 attachment content search Outlook VBA and Custom Forms 2
glnz Can Word Normal.dotm interfere with Outlook? Office 2016 Using Outlook 5
D Outlook 2016 and Earlier with Office365 in 2021 Using Outlook 3
B Outlook 2016 Retail C2R keeps logging since update? Using Outlook 0
R Microsoft Outlook 2016 - Gmail not sending, asks for password for SMTP, tried different ports Using Outlook 23
M Office 2016 Outlook is forgetting passwords Using Outlook 15
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
A Outlook 2016 in Cached Mode Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
GregS Outlook 2016 Outlook 2016 stalls Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
K Outlook 2016 Using Outlook 0
A Outlook 2016 not synching Using Outlook 4
B The Outlook 2016 Profile that isn't always there Using Outlook 2
