Forward Appointment as BCC with VBScript
mathiasd
i am pretty new with VBA and I have the following requirement.
I want to forward every incoming appointment to a BCC receiver.
I just used this example which sends every appointment to an email receiver - but not with BCC:
Dim Ns As Outlook.NameSpace
Dim Folder As Outlook.MAPIFolder
Set Folder = Ns.GetDefaultFolder(olFolderCalendar)
Set Items = Folder.Items
Dim Appt As Outlook.AppointmentItem
If TypeOf Item Is Outlook.AppointmentItem Then
Set Appt = Item
Appt.Recipients.Add "xxxx@yyyyyy.zz"
Appt.MeetingStatus = olMeeting
Appt.Save
Appt.Send
Is there a way to modify the above coding in a way that the appointment will be send with blind copy (BCC)?
Many thanks in advance
mathiasd
many thanks for your fast reply Diana :)
Is this sequence ok?
Set Appt = Item
Appt.Recipients.Type = olBCC
Appt.Save
Appt.Send
..or should it be the other way around?
Set Appt = Item
Appt.Save
Appt.Send
I really appreciate your help!
thisi s the correct order -
mathiasd
Run-time error '438': Object doesn't support this property or method
Guess .Type is not available for Outlook.AppointmentItem
Michael Bauer
A small change does it. You cannot set the type for all recipients at once but have to do it for each single recipient.
dim r as recipient
set r=Appt.Recipients.Add ("xxxx@yyyyyy.zz")
r.Type = olBCC
J Outlook 2010: can't forward appointment on custom form Using Outlook 1
C UDFs Reply vs Forward Outlook VBA and Custom Forms 3
C How to rename subject line and forward the email Outlook VBA and Custom Forms 2
C Don't forward duplicate Using Outlook 0
I change subject and forward without FW: Outlook VBA and Custom Forms 4
J Forward Action in Form Outlook VBA and Custom Forms 1
Brostin Forward a mail to the address listed in the email text Outlook VBA and Custom Forms 1
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
J Forward Message after editing attachments and include edited attachments Using Outlook 5
A Creating an outlook rule to forward an email with a specific message Using Outlook 1
D Forward message to address from subject Outlook VBA and Custom Forms 1
D How to forward each email x minutes after it arrives in inbox and hasn't been moved or deleted? Using Outlook 1
W Macro to forward email Outlook VBA and Custom Forms 2
J How to change From then forward message Outlook VBA and Custom Forms 1
S Reply & Forward Date in original message incorrect Using Outlook 2
Diane Poremsky Forward Messages that were not Replied To New Slipstick.com Articles 0
mikecox Forward email to another address; not with Rules Using Outlook 3
divan Macro to format email in a certain folder then forward to email address Using Outlook 3
D forward email with attachment using .oft Using Outlook 3
J Forward a bounce mail? Using Outlook 1
P How to save sent mail and forward it the next day Exchange Server Administration 3
T outlook 2013 does not mark multiple forward messages as forward Using Outlook 2
D Forward Only an Attachment Using Outlook 1
G Capture "forward event" ? Outlook VBA and Custom Forms 11
R Auto-create receipt from email and forward to payer Using Outlook 3
L Auto Forward without presenting the original sender Outlook VBA and Custom Forms 1
C Unable to forward email with URL Using Outlook 2
C Button to Forward and Move Using Outlook 4
