Outlook for G Suite emails showing wrong dates
zillah
Dear folk
I migrated POP3 emails from outlook 2016 to G Suite (Gmail for business) server by using their dedicated utility ,,,,migration done successfully.
Then I set up a new IMAP G suite account on outlook,,,,all emails got downloaded from the google server
Issue are subfolders view left pane showing emails' dates as Sun 21-Jan ,,,but if you open a specific email in those subfolders it is still showing the right dates,,,issue only with view
Inbox and Sent emails have no such issue
How can I rectify this issue ?
Second issue sent emails don't get downloaded from the server to the outlook client , lase email I got was dated 17.Jan.18
zillah
Issue persists since I am using G Suite (Gmail for business) I contacted their support and they advised me to use a different client for a testing purpose and I did use Thunderbird no issue at all with emails dates.
Hence G suite support advised me issue with Outlook not with G Suite
Dates that outlook is showing are migration dates when I migrated outlook to G Suite server
Regards
T Outlook 2013, McAfee Security Suite and SMTP/POP3 Using Outlook 3
S Outlook 365 Can I change the possible range of highlighting colours when writing an Outlook email? Using Outlook 1
B Outlook 213 keeps crashing. I just found out there are DMP files. How can I tell Why? Using Outlook 2
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 13
@ Outlook Using Outlook 2
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
