Outlook 2010 will not send nor receive
Nickajack910
I have Outlook 2010 as part of a complete Office 2010 Program. This started Monday when I discovered I was not receiving any email and an outgoing email was still in the Outbox. I clicked on File and discovered this Hotmail Connector Upgrade message. I allowed the program to run way more than 15 minutes, and nothing happened. Closed and reopened the program, even did a reboot, and nothing different. I read you post about someone else with this problem. I did a repair of the Outlook Connector, uninstalled it, downloaded a 32 bit Connector from Outlook. The Upgrade message was still there and no send nor receive. I tried to do a repair on Office 2010, got about 3/4 of the was through, and it gave me a message, it didn't access to C:\Config.msi\17c5748,rbf, then it backed out and reversed the repair and required a reboot. If I try to do a manual send and receive, I get an error message: Not Implemented.
As a side issue, I have an installed Outlook 2016 standalone program on the same computer that works. It will send and receive fine. It has a problem with inserted pictures, in that it will not give me a Format Tab when the image is selected, nor will it allow me to crop. I saw your suggestion of copying winword.exe when you have two different versions of Office programs. I did that too, and still no Format Tab.
What I have is a mess. I really don't like the format and design of Outlook 2016 as well as Outlook 2010. What do you recommend 2010, doing a disk repair of Office 2010? I may have to get permission from Microsoft to do a reinstall if I uninstall it. Thanks.
No... this does not work anymore. You need to make sure you have all updates installed and add the account using auto account setup - it will add it as an Exchange account.
A client had the screen yesterday - we waited 15 min or more then did a repair on Office and he rebooted. It went away shortly after - total time passed from when we first saw that message was maybe an hour, or just over an hour.
You should uninstall the connector you installed - I'm actually surprised you found a copy, Microsoft said they removed it.
I'm not sure why the format tab is missing - if word added it or it came from somewhere else. Did you check in File, options, customize to see if you can display it?
Nickajack910
Thanks for the suggestions. I've decided to try and find the Format/Picture tab that is missing. Attached is another discussion you had with someone else regarding the missing tab. My Outlook 2016 works, except for the picture edit, and I am happy with that. I also saw yesterday that there is a Classic Menu software available that will make Outlook 2016 look like Outlook 2010. www.addintools.com/index.html Do you know of any problems using this software? The price is $29. Thanks Diane.
I am not aware of problems and have not tried it - i figure the ribbons are not going away and i might as well get used to them. :)
I don't have an outlook-only install to test it. The last time i tested it was with outlook 2010 - the insert ribbon has some things disabled.
Outlook 2010 Standalone's Missing Features
Nickajack910
The Classic Menu has a free 15 day trial. I installed it. So far, I'm impressed! I will use it for a few days and probably buy it. They have discounts for multiple downloads.
E How to send automatic emails in outlook 2010 Using Outlook 1
D Outlook 2010 hangs during message send/receive Using Outlook 2
S Outlook 2010 won't send on Windows 8 Using Outlook 2
V Outlook 2010 – Send email based on categories Using Outlook 2
R Outlook 2010 Send from other email address uses account address instead Using Outlook 1
N Outlook 2010 take long time in send / receive Using Outlook 1
J Email won't send Automatically in Outlook 2010 Using Outlook 3
H outlook 2010 email can't send to other domain Using Outlook 1
H Outlook 2010 unable to send iCloud account e-mail after iOS 7 upgrade Using Outlook 12
R outlook 2010 can't send email Using Outlook 0
I How to send just a few emails at a time to a large group in Outlook 2010 Using Outlook 3
O Outlook 2010 Stops Working When Accounting Application Tries To Send eMail Using Outlook 4
D Emails stuck in Outbox, not receiving emails, Outlook 2010 auto send/receive Using Outlook 4
J Outlook 2010 will not send messages due to Date: None Using Outlook 1
D outlook 2010 table format lost on send Using Outlook 1
R Outlook 2010 Not Recieiving Emails Automatically, Have tohit Send / Recieve Using Outlook 1
T Outlook 2010 manually actioning of send and receive? remove auto actioning Using Outlook 4
D Outlook 2010 Fails to Send Messages To One Domain Using Outlook 6
I Send Secure Email Through Microsoft Outlook 2007 and 2010 (32 bit) Using Outlook 0
B Send/Receive Status in Outlook 2010 Using Outlook 2
K Outlook 2010 'cannot send on behalf of' when changing calendar apointment Exchange Server Administration 0
H Outlook 2010 : Error while preparing to send sharing message Exchange Server Administration 8
A Outlook 2010 - can't send/receive data file cannot be accessed Using Outlook 10
