Searching for Custom Flags
outlookbluesemail
Outlook 2016 64 bit
Outlook 2016-64bit on Windows 10.
I have a partner who uses Custom Flags for associating emails into "Case Numbers"
He will assign a Custom Flag, for instance 1001, and can have 1 to many emails flagged with 1001. It actually works pretty effectively for him, however the built in search function does not seem to be able to search Flags based on their custom names. Advanced search options don't seem to be of any help either. We tried looking at Categories, but he's thousands deep in this Custom Flagging and switching isn't an option.
Anyone have a plugin for searching based on Custom Flags or any other options I should be looking at?
outlookbluesemail
Outlook 2016 64 bit
Thank you. I should have pointed out that the Flagged emails will reside in different folders, thus the request for a search function.
Search folders will work as long as they are all in one data file - create a search folder for all flagged items then add the Follow Up field to the view (i think that is the correct name) and group by it.
AFAIK, that field is not exposed in instant search, so your options are somewhat limited, but the search folder should help.
Using Search Folders
D Searching for Data in a custom form Outlook VBA and Custom Forms 1
geoffnoakes Outlook 2016 Searching based on CreationTime Using Outlook 3
P Searching tasks that are archived Using Outlook 4
M Outlook 365 Searching all shared calendars Outlook VBA and Custom Forms 4
B Searching for a Add-In Using Outlook 3
J Searching message folder in Outlook 2016 Using Outlook 5
C Outlook 2016: Searching in all (+public) folders Outlook VBA and Custom Forms 9
Diane Poremsky Searching for Outlook Items in Windows New Slipstick.com Articles 0
M Searching multiple folders Using Outlook 6
W Searching Flagged Email Outlook 2013 Using Outlook 1
E Searching a Shared Outlook Mailbox from the start menu? Using Outlook 4
Rijotech Fast searching from:name and date Using Outlook 3
S Searching contacts across GAL and local address book at same time Using Outlook 1
A Searching for text in Contact notes Using Outlook 2
M Searching for categories not in the master category list Using Outlook 3
P Searching By Contact Categories Using Outlook 0
B Searching OWA Additional Mailbox - in which Secondary folder is the email? Using Outlook 1
R searching a not function Using Outlook 2
R Searching emails sent/recieved on a specific date. Using Outlook 2
M Searching Outllook 2010 shared contacts from Outlook 2007 Using Outlook 4
G CTRL-E is not searching I-cloud contacts Using Outlook 2
M Jolly characters in Outlook 2007 searching Using Outlook 3
E Does Outlook 2010 support searching multiple .pst files simultaneously? Using Outlook 0
D searching Outlook 2010 Calendar Using Outlook 1
M searching mail Exchange Server Administration 5
R Instant search is only searching Archive files, not all files Using Outlook 8
B Searching across public folders in EXCHANGE 2007 Exchange Server Administration 2
K about find mail or searching mail Using Outlook 2
L Searching and delegate mailboxes. Using Outlook 4
D I see two of every result when searching in Outlook 2010 Using Outlook 2
J Microsoft Outlook 2007 on Windows 7 search function stopped searching attachments - it use to search Using Outlook 1
C Outlook 2010 not searching very well Using Outlook 1
M Searching Archived Folders - Not finding sent items Using Outlook 1
K Searching Contacts after upgrade to 2010 Using Outlook 1
H Searching Public foldersin Outlook 2010 Using Outlook 2
X outlook 2007 error when searching Using Outlook 7
T searching for attachments that have a certain "text" in the name Outlook VBA and Custom Forms 2
