Copy e-mail body from outlook and insert into excel
elbrodero
I have an e-mail and want to copy its body into excel into separate cells divided by ";".
So I have a mail that looks like this:
hello; Bye Bye
And I want to copy into to excel so it looks like this:
A1 B1
Hello Bye Bye
Although this seems like a very generic problem I cannot find any help online.
It should work - but will depend on how the Text to Columns feature is working. In my experience, you need to convert once manually and it will usually use the same conversion for future pastes.
Depending on how often you need to do this, you could use an Excel macro to paste it correctly.
elbrodero
So my e-mail looks like this:
Bla
bla
bla
bla
bla
Code 0001:
Number Cust-Nr. ]Data Val.-Date Gesamtbetrag Belegw{hrung
helo _000000 0000000000 06.03.2018 12.03.2018 1.000.000,00 EUR
Code 0002:
AVIS-Nummer Kunden-Nr. ]bertragungsdatum Val.-Datum Gesamtbetrag Belegw{hrung
The code I use is the following:
Option Explicit
Sub EmailText()
Dim ObjOutlook As Object
Dim MyNamespace As Object
Dim i As Integer
Dim j As Long
Dim abody() As String
Dim rstart As Range
'Declare Variables
Set ObjOutlook = GetObject(, "Outlook.Application")
'Find the outlook application
Set MyNamespace = ObjOutlook.GetNamespace("MAPI")
'Find the "NameSpace" -Current user environment from outlook
For i = 1 To MyNamespace.GetDefaultFolder(6).Folders("CP").Items.Count
'loop through all the items in the temp folder, defaultfolder(6) is the inbox.
abody = Split(MyNamespace.GetDefaultFolder(6).Folders("CP").Items(i).Body, Chr(13) & Chr(10))
'for each item, "split" the body of the email by linebreak into an array
Set rstart = ThisWorkbook.Sheets(1).Cells(65000, 1).End(xlUp).Offset(1, 0)
For j = 0 To UBound(abody)
'For each item in the array (i.e. each line) add the line to the first empty cell in column A of sheet1
rstart.Offset(j + 1, 0).Value = abody(j)
MyNamespace.GetDefaultFolder(6).Folders("temp").Items(i).Move MyNamespace.GetDefaultFolder(6).Folders("Processed")
'Move the email to the processing folder
Set ObjOutlook = Nothing
Set MyNamespace = Nothing
'Clear the object variables. I don't think this is needed, but it's good practice.
the problem is that the code only copies this part into excel:
Bla
bla
bla
bla
bla
Code 0001:
Then a bug appears in line
elbrodero
So the problem is solved by deleting Chr(10)
However, I have another question. Would it be possible to copy this part of the e-mail:
Code 0001:
into a specific range within an existing excel file
and the other part of the e-mail
Code 0002:
into another rather of the same excel file?
L auto copy text in mail body to other part of the body Outlook VBA and Custom Forms 1
F How can i copy the mail subject and the link to the mail to th clipboard? Outlook VBA and Custom Forms 3
L "sometimes" cant send mail, we have to copy and paste the message and resend? Using Outlook 2
G "on behalf of..." not showing on Sent e-mail copy, but is on Delivered copy Using Outlook 5
Diane Poremsky Copy New Appointments to Another Calendar using VBA New Slipstick.com Articles 0
Diane Poremsky Use a macro to copy data in Outlook email to Excel workbook New Slipstick.com Articles 0
Q Why can't I copy image with embedded hyperlink from email to Word Using Outlook 0
I How to make a copy of a task Using Outlook 8
F copy data in Custom Field to other folder Outlook VBA and Custom Forms 2
A Outlook: copy & paste Outlook VBA and Custom Forms 9
L Copy email body fields to excel Using Outlook 0
