Adding Macro to populate "to" "subject" "body" not deleting email string below.
Melsbe
Outlook 2016 64 bit
I found macro details to enter the "to" "subject" and "body", however when using the signature and email string disappears. What i'm looking for is the code so that the email string below the body macro doesn't disappear.
My idea is to highlight a message I want to forward, then auto populating the To, Subject and body with certain text, it is working however i'm loosing the email string below.
Using Code:
Sub PreAlert()
Dim msg As Object
Set msg = Application.ActiveInspector.CurrentItem
msg.Forward
msg.To = "BT"
msg.Subject = "Pre-Alert: PO - FEDEX -"
msg.Body = "PREALERT" (would like to have a hard return inserted)
msg.Display
Any Assistance would be greatly appreciated.
Thanks Eddy
Melsbe
Outlook 2016 64 bit
Thank you for your information, adding the code worked. However, what I had not mentioned and maybe I should have, the email is in HTML and needs to remain in HTML, as there are links in the body of the email that needs to remain. Adding the code kept the body however it changed to text. Is there a code that when forwarding the email, the body of the email would remain in HTML? Below is a sample of the email body.1520857897028.png
Thanking you kindly,
Eddy Melsbach
Melsbe
Outlook 2016 64 bit
then use htmlbody: msg.htmlbody="xxx" & vbcrlf & msg.htmlbody
you might need to use html tags though:
msg.htmlbody="<p>xxx</p>" & msg.htmlbody
Thank you so much Diane,
This worked. Could you suggest a site where I can review all the VB code for outlook?
Eddy Melsbach
W Adding A Macro To Message Ribbon Outlook VBA and Custom Forms 2
S Adding follow flag for me by macro (MSO2007) Outlook VBA and Custom Forms 3
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
O Adding a new account - "CompanyL (none)" line is added Using Outlook 5
I Collecting mail address from GAB and adding to Outlook Task Using Outlook 2
A Outlook 2016 - adding outlook.com account creates a new/strange address Using Outlook.com accounts in Outlook 18
F Adding textbox filter to listbox? Outlook VBA and Custom Forms 2
J Adding Reply & Delete to main toolbar? Using Outlook 0
T Outlook 2007 adding categories Using Outlook 15
Diane Poremsky Adding Emojis to Outlook's AutoCorrect New Slipstick.com Articles 0
T Adding "Mark As Complete" btton to Task Remindet Pop-Up Using Outlook 3
Ascar_CT Adding contacts on Android phone and then syncing them to Outlook Using Outlook.com accounts in Outlook 4
A Adding a 2010 sharepoint contact list to outlook 2010 address book Using Outlook 1
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
S Using Send on Behalf is adding extra data in from line Using Outlook 1
Lucylou Outlook 2013 Adding Outlook.com breaks profile, "Outlook not working" messag Using Outlook.com accounts in Outlook 1
C Adding Categories when Composing Email Using Outlook 1
stephenjones Adding a business account to Outlook Using Outlook 1
Chris Grew Adding 2nd Email Address BCM (Business Contact Manager) 3
G Adding an attachment to email I just created (VBA) Outlook VBA and Custom Forms 1
L Adding sender's e-mail to global address book DL Outlook VBA and Custom Forms 1
R Adding vba to script list Outlook VBA and Custom Forms 4
F Adding User Defined Field to another form Using Outlook 0
Edaniels Adding Week Number on Calender Using Outlook 2
I Adding appointments/tasks to other user's calendar Using Outlook 1
J Adding original email text to outlook message template Outlook VBA and Custom Forms 2
Commodore Editing contacts and adding photos Using Outlook 4
D adding web address to email Using Outlook 1
