Outlook 2016 with imap emails keep Resurrecting themselves?
CWM030
Windows 7 Home
Personal domain
Account is set up as IMAP
I am having a problem with a email popping back up long after their deleted out of their respective folders and the trash can has been emptied?
The problem account is a GMAIL account that's set to forward to my domain address then disregard the email after it's been forwarded to my domain.
The forwarding setting was set up using gmail.com ( Outlook is not doing the forwarding)
I have not changed any special settings / settings in general in Outlook.
What could be causing this?
I've deleted that certain email 3 times already this evening.
Chris
CWM030
Are you sure gmail didn't receive and forward 3 copies?
Thats very odd.... OL 2016 doesn't alert you to new email's in sub folders.. I had no clue until just now, that you replied to me.
To answer your question. No, because I even emptied gmail's trash can and it still reappeared. But, weirdly, it has stopped now.
it should if an outlook rule is moving the mail - if you have gmail filtering the mail before outlook gets it, then no.
CWM030
Other way around........ The filtering doesn't happen until the emails get to OL.
But, Outlook does not tell me that there's email's in sub folders for some reason :(
You should get the envelope notification - if you need notification, you can add either of these actions to your rules: display desktop alert (the little popup that goes away) or an alert that stays on the screen till you dismiss it. Or you can play a sound...
Y IMAP errors with Outlook 2016 Using Outlook 2
Liz Schneider PST from Outlook 2013 is now IMAP folders in 2016 Using Outlook 10
I Outlook 2016 and Slow access to Outlook.com IMAP Using Outlook 0
M Office 2016 Outlook is forgetting passwords Using Outlook 14
GregS Why is Outlook 2016 mail in Outlook.com? Using Outlook 1
A How to open a specific link automatically with outlook 2016 Outlook VBA and Custom Forms 5
C Outlook 2016/2019 hangs after being open for an extended period Using Outlook 4
A Outlook 2016 in Cached Mode Using Outlook 1
N Outlook 2016 Folder Icons Look Using Outlook 0
GregS Outlook 2016 Outlook 2016 stalls Using Outlook 3
H Outlook 2016 sent over 30 copies of an e-mail with attachments Using Outlook 1
K Outlook 2016 Using Outlook 0
W Search Incomplete Outlook 2016 Using Outlook 5
A Outlook 2016 not synching Using Outlook 4
B The Outlook 2016 Profile that isn't always there Using Outlook 2
J Command Button to stamp a date and time in a textbox in Outlook 2016 Outlook VBA and Custom Forms 3
J Checkboxes when selected will appear in a textbox in Outlook 2016 Outlook VBA and Custom Forms 1
N Outlook 2016 Address Book lookup Using Outlook 9
D Outlook 2016 automatically increment anniversaries Using Outlook 1
D Sharing outlook.com calendars in Outlook 2016 Using Outlook 1
M Outlook 2016 Requesting data from server Using Outlook 0
